I am looking for the original repair parts for my prefab fireplace. Make: Empress heat circulating fireplace Model 736 or 737. I want to rebuild the inside. Thank you for your help. Elisabeth
  • 1 more comment
  • cdumelie Sep 18, 2010
    Did you find what you were looking for? If you did, I have the same problem. I would like to replace the insert for my fireplace; same model.
    cdumelie@sasktel.net
  • Chimney Chick
    Chimney Chick Aug 14, 2014
    Empress Fireplaces are no longer manufactured and there are NO replacement parts available. Since these units are pushing the 30 year mark I would strongly suggest having a Certified Chimney Sweep out to look over the entire installation as the fireplace and chimney may have passed their prime and are in need or replacement. These fireplaces only lasted about 25 years ..
  • Lineze Schultz
    Lineze Schultz May 12, 2016
    No problem. You can order us for cheap and strong prefab building. This is very cheap and we meet all demands of our customers.http://aussiepanel.com.au
Do you happen to have the manual for the 736-737 Empress fireplace?
Posted on Jan 13, 2014
  • Chimney Chick
    If anyone has one of these original manuals please den me a copy for my archives, thank you yvette@aimsweep.com
The heat on my Pyromaster HEF33 Electric Fireplace is not working
This unit was made by Monessen Hearth Systems. The original heater/fan part has been discontinued; however, there is a new part that is compatible with your fireplace. You will need to search for part#10006404 Fan/Heater.
Nov 30, 2012 | Leisure HOMEPRIDE Electric Fireplace...
I have a Amish looking electric fireplace, Model FL18-r, which has quit heating altho the fake flames still work. I am trying to see if the heater insert can be replaced, where and for how much, or...
There are a couple of reasons the heating unit part of the fireplace stop heating. A dust and lint build up in the heating coils can cause them to burn out. The heater overload circuitry has shut the heater down or has failed or the unit needs to reset. so lets go to the easiest thing for you to do, yourself.
RESETTING THE HEATER
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace and wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON. Turn ON each individual function of the fireplace, one at a time. If the unit was able to reset itself, each function should work normally. If it doesn't, then one of the issues I listed above is the problem.
If your fireplace is less than one year old, it should still be under warranty. So contact the manufacturer (you can find the contact info in your Owners Manual) about repair or replacement.
One personal aside: None of the electric fireplace/heaters on the market today, have a long trouble free life span. Usually, it's 9 months to a year, when consumers start having problems. I sold these type of appliances for a couple of years, as an adjunct to our gas fireplace and heater business. When they started to become a problem for our customers, we quickly realized, that no matter who the manufacturer is/was, they are not what they are touted to be and we discontinued selling them. It's been 4 years since we discontinued selling them and apparently, nothing has changed in their manufacture. As, I answer more than my share of questions about them, here on FixYa. As one person told me, "I wish I had bought a vent-free gas fireplace instead. It would have cost me more, but would have been more reliable and would still heat, even if the power was out."
I hope this helps you trouble shoot and solve the problem.
Happy Easter!
Apr 23, 2011 | Heating & Cooling
I'm looking for a user manual for a Superior Gas Fireplace model FAK 1500. I want to know how to take off the front glass as it has become covered in a white residue.
The fak 1500 number is for the blower assembly. I found this manual for a fireplace using the blower assembly. hope it is what you are looking for. Lennox has bought out the fireplace company and there are no manuals available under superior.
Feb 11, 2011 | Heating & Cooling
My home has a steam boiler that supplies heat for the 1st and 2nd Floors. There is a hot water system from the boiler with an InLine Armstrong circulator pump that supplies heat to the basement. The pump...
Yes, the manufacturer should have a parts kit for replacing the orings and seals..it's probably leaking right where the motor meets the impeller...there should be a seal inside there...the rebuild kit should have a blow-up diagram to assist you in changing parts
Jan 22, 2011 | Armstrong Tool Armstrong S25 BF InLine...
I am looking for an installation manual for Model FUBSK blower motor kit. We bought a new home and the Lennox Superior wood burning fireplace Model BC-36 has a switch that should force heat out into the...
The fan should be installed behind the bottom grill, and then it should blow air around the firebox which then exits out the top grill. Now saying that, let me explain the actual problem you will face. Because you have a open faced wood fireplace, you will not get the heat your looking for, the fire needs 400 cubic feet of air per hour and that air is taken from your opening. Also the inner box doesn't heat up enuff to produce alot of heat on the skin so if you have the fan blowing full blast, it will only cycle the air and not allow it time to heat up as it cycles around the box. I suggest turning the fan speed down so its 1/2 way on or lower, this allows the air time to heat while cycling around the box, but in the end you still won't have a good heater as the fireplace itself isn't one, you should look at having it converted to direct vent gas or ripping it out and replacing it with a airtight wood.
Jan 03, 2010 | Superior Lennox Blower Thermal Sensor -...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
339 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
