Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore oven locked after celf cleaning
How do I get my Kenmore oven unlocked after self cleaning mode?  It has been locked since the self cleaning has since ended over 10 hrs ago.  I tried hitting cancel many times and unplugging it for a few minutes after self cleaning was done. my oven would not unlock. it had a code E1 F5.
  • babyboo0311 Oct 06, 2008
    my amana was on self clean after it got done it wont unlock help!!
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Door is lock
How to unlock Kenmore oven - YouTube
? 1:07
www.youtube.com/watch?v=xnwnLi8Ld5I
Jun 30, 2013 - Uploaded by Imi Chitterman Kenmore oven lock and unlock after self cleaning. ... What should I do to get my oven door open please? I pressed the start button but it didn't ...
www.partselect.com/.../Range-Stove-Oven/Door-Will-Not-Open-After-S...
If the door will not unlock at the end of the clean cycle then you may have a problem with the oven temperature sensor. Most electronic control ovens will display ...
Nov 05, 2015 | Kitchen Ranges
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
I Have a C970-648229 and after self cleaning mode stove top stays locked out.
Have a similar problem. The range went on locked mode w/o it being used. Disconnected the cable & it unlocked but the touch panel would not work. The clock & the stove top continuos to work though. Appreciate any help. Thank you.
Sep 09, 2012 | Kenmore Kitchen Ranges
Hi, my kenmore elite oven (#79075503207) has been on cleaning mode for the last 3 days, it is still making a noise and door locked. please help.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 11, 2010 | Kenmore Elite Stainless Steel 40" Dual...
My oven door will not unlock after cleaning
It will take some time for it to unlock. The lock after self cleaning is controlled by temp. The temps during self cleaning are over 900 degrees and after self cleaning it will take several hours before the oven lock will release. Don't try to force. If after 3 hours it has not unlocked you can try disconnecting power for 2 minutes then reconnecting to activate the self cleaning motor assembly. Good luck and thanks for using Fixya
Feb 23, 2010 | Kenmore Ovens
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
Oct 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
335 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
