Question about Kenmore 15762 Dishwasher
What part do I need to replace?
What part do I need to order and how difficult is it to replace?
  • 481 Answers
  • ok, thanks for the full model number. it is just little micro switches that you have to change.
  • You will need to turn off the power to the machine first, possible turning off a breaker.
  • Then you take off the inner door panel to get to the door latch/switch assembly. It is not too hard but it would be helpful to have someone that is comfortable repairing such things.
  • remove the bottom kick-plate at the bottom of the machine.
  • behind it should be some springs with cables attached to them, unhook them to release the tension on the door ; so you can lay the door all the way down without it trying to lift up while you work on it.
  • now you can take the screws out that hold the inner plastic panel.
  • once this is off you should be able to see everything including the little switches.
Posted on Aug 12, 2008
HTC T320e One V screen replacement
You want to Google HTC T320e screen replacement and find a YouTube video of the process. You can then decide if you can do this. Hint: When you order the replacement part, order the kit with the tools. The torque screwdrivers are small and hard to find at hardware store.
Feb 16, 2014 | HTC Cell Phones
The lights indicated that I needed to replace my lamp. After doing so, the TV still doesn't have picture. What do I have to do to get it to work?
It is possible that the Ballast is not turning on the lamp. In past years it had been difficult to get the Ballast separate from the Optical Block but they seemed have them available. In order to replace it you will need to remove the Optical Block which is in the center. The ballast assembly is mounted on the right side of the OpticaL Block. Once the Optical Block assembly is removed, it is not difficult to replace. To order a Ballast, call 1800-631-3811. You will need the model number.
I hope this helps,
Skyassoc
Dec 10, 2010 | Toshiba 62HM95 62" DLP HDTV
I think the clutch is worn on my yamaha xjr400 1998' Would it be difficult to replace and are they costly.
.. Hi there, i have an XJR400 myself. You really don't need a puller to remove the clutch plates. It's recommended but you don't really need it.
To answer your question, It's not difficult to replace and the parts are costly (I ordered it in japan)..
Hope you got your answer,
levibit
Feb 17, 2010 | 1998 Yamaha XJR 400
Temp setting worn off and difficult to set temp
call region repair center to get & order new temp control dial.
Nov 17, 2009 | Kitchen Ranges
My drivers window has broken and fallen in. On my 98 vw passat
Not all that difficult of a job. The window will fit directly into a glide, need to be secured, etc. You will need to remove the interior door liner in order to gain access. Unfortunately the glass is probably totally shattered, so it may be difficult to see exactly where the windo needs to be mounted.
Aug 18, 2009 | 1999 Volkswagen Passat
Need a starter
It depends on the location of the starter. Mine is difficult but you have to know a little mechanics in order to do this, if no experience well tough luck. Now, in order to start a problem start, try tapping the starter with a hammer or metal pipe, you might need to get under the car or raise it enough to access the starter, raise it safely!! don't be afraid to hit it hard beucause you can have a stuck piston inside that needs to be freed. CAUTION bad starters can cause damage to the fly wheel!!!!
Aug 12, 2009 | 1994 Mazda Protege
Transfer belt nees replaced
find samsung dealer,not hard to replace.
Jun 03, 2009 | Samsung CLX 3160fn All-In-One Printer
Cook top replacement
If you're willing to give it a try, you can follow this link for instructions on how to replace a cooktop.
http://www.fixya.com/support/r391448-replacing_glass_cook_top
You're right, its not difficult. But, it can be tedious. Take your time and please post back with your complete model number if you need further assistance. Searspartdirect.com is a great website that has exploded view illustrations to assist you in troubleshooting and/or assembly. I hope this helps you.
Jul 22, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore 15762 Dishwasher Logo
64 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
