Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
"Help" Missing refrigerator door sensor & compressor is continuously running..
I bought a used Kenmore 27 side by side refrigerator and the compressor is continuously running...I'm faily certain it hasn't shut off since I plugged it in 48 hours ago. It's missing the "refrigerator" door sensor. Could the break in the signal from the missing refrigerator door sensor and the freezer door sensor that causes the digital display to read that the door is open be the cause of the compressor not shutting off??? Model 363.9527821 serial # L226 10814
  • 958 Answers
Could be, since if the computer senses that the doors are open, then he would turn the compressor continuously in order to compensate for the losses of an open door refrigerator.
but with this kind of alarm, im sure it should have turn the refrigerator off if it has been sensing that the doors are open for the past 48 hours.
another thing to consider is that since it is second hand, it could have been repaired and things done to it for the compressor to run continuous.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
Kenmore elite french door refrigerator and freezer not cooling
Check the compressor start device. The fans will be running and the compressor fan will be running but the compressor is problaly not running. If it is then it could be the compressor itself that is not oumping.
Mar 25, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Does not cool
http://www.youtube.com/watch?v=sylSVZKGB9I
I repaired a kenmore french door refrigerator last year for my neighbor. It wouldn't cool, and the compressor continually clicked but never came on. I replaced the capacitor (weak) and the claxon mounted on the compressor housing. If you don't hear a clicking from the compressor (under the bottom of fridge), and you can hear the compressor running then it might be your defrost heaters. http://www.youtube.com/watch?v=sylSVZKGB9I
Aug 24, 2013 | Kenmore Elite 33 cu. ft. French Door...
Not starting after being left open all night.
You may have burned out the compressor motor as it was forced to run all night trying to cool the unit with the door open. The compressor motors in home refrigerators are not designed for running continuously. Call 1-800-KENMORE for help.
Feb 11, 2012 | Kenmore Refrigerators
Fans in refer/freezer run continuously
it suppose to run so long the compressor is running it goes into defrost every 8 or 10 hours or it shuts off if it reaches temp but if you can hear the compressor running and the evap fan aint running somethings definitly wrong
Nov 03, 2009 | Kenmore Refrigerators
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
We have a Kenmore 596.50399001 side by side refrigerator. The center divider can get very hot, the refrigerator compressor is running but not the fan. If the refrigerator is moved or shook the fan will...
If you are talking about the freezer fan motor, it should be running if the compressor is running.
if the compressor runs without the fan running the compressor will overheat and become damaged.
The mullion heater in the door divider is not affected by the compressor.
Mar 13, 2009 | Kenmore Refrigerators
Fridge and freezer not cooling
Compressor is probably out on thermal cutoff from trying to restart continuously. You can get what they call a hard start kit at a parts house. Its a plug and go unit.
Jan 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore mod.# 50522101
hi is the compressor running if it is you bought a dud sorry
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Temperature Displays Flash
just stop getting cold, both sides no ice, everything runs, bought new, sat in storage 3 years, been running 2 years
May 15, 2008 | Kenmore 44353
Refrigerators Logo
263 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
