Samsung HLS4666W TV Turns off at will
Hi - I have owned this TV now for 2 years. 6 months ago the lamp conked out and I replaced it. It worked fine for 2 months but now TV turns off without any prior warning. It happens 3 or 4 times at intermittant timings, 15 minutes, 2 minutes, etc. When I persist to keep turning it ON, it starts behaving and keeps on as long as I need to keep it on. I can't find this problem mentioned anywhere and therefore can't find any solution either. Does any one know what the problem is and its fix? Is anyone else having the same problem. Advise. Thanks
  • sginct Aug 15, 2008
    Thanks. Looks like it was a connection after all. I can't be sure but I took both rear panels and the lamp out, made sure all connectors are snapped into place. I did heat a click from one of them. I don't believe I ever touched connector that but it has worked fine since yesterday morning on 3 different attempts.
  • 4,234 Answers
This sounds more like a connection problem that resolves itself as the set "heats up". One other thing to check is the lamp door. These sets have interlocks for the doors etc. that will cause the set to shutdown if not shut correctly. This could be part of the problem as well. Unless you can find a detailed pattern to the behavior, tracing this will be difficult. Look for loose cable connections or bad solder connections on the boards as well as any access doors that may not be closed or seated properly.
Keep us posted.
Dan
Posted on Aug 14, 2008
  • 157 Answers
Hello sir
  • John Smith
    John Smith Aug 14, 2008
    Make sure that there is no dust around the lamp. you may want to try and clean around the lamp with a blow dryer.
    Cheers
    JigSaw
    XoXo
After fixing a ballast lamp and color wheel how long would a tv last?
I have the same telly for the last six years and i only changed the lamp two weeks ago i think there a very good telly
Jan 20, 2013 | Samsung SP50L6HX 50" DLP HDTV
I also have the white spots problem with my Samsung 46" DLP. My set is 2 1/2 years old, and was fine until a couple weeks ago, when 1 then 2 white spots appeared. Presently there are 10 spots and rising....
The DMD chip is failing. The little mirrors on it are sticking in the on position therefore always reflecting the white light from the lamp. The part number you will need is 4719-001981 and is available from the Samsung parts website. I have included a link to directly purchase the part from them. Please take a moment to rate my answer. Thanks...
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=4719-001981&search%5Fmodel=HLS4666W
Nov 26, 2009 | Samsung HLS4666WX 46" HDTV
TV turns off
Your Ballast Board could be problem Now, pull back off watch as Lamp trys to turn on if there is a Spark coming from Ballast Board Lamp is Defective, If No Spark problem is in Ballast Board.
Sep 21, 2009 | Samsung HCM5525W 55" Rear Projection...
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
TV on/off
How long is your TV on before it turns off? Check the fans and make sure they are all working. The TV may be shutting off due to overheating if a fan quit working.
If you think the lamp is still good maybe try replacing the lamp ballast.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP6163W Problem- TV keeps turning off!
Well, I have had the same exact problem and since my hlp6163w is still under warranty, I had a technician come out to repair it. And...the winner is a bad ballast. The Ballast has also affected the bulb. So, the answer is you need to change the Ballast and the lamp to get the problem resolved. A faulty Ballast will always destroy a a lamp. Sorry for the bad news as this will cost you a total of $400.00 to replace. It sounds like there is a defect in the ballasts that were made for this particular set and a recall should be made. Hope this helps!
Jun 11, 2008 | Televison & Video
We have a Samsung HLP5674WX/XAA which seems to have a mind of it's own. It will automatically shut off or when we turn it own, there will be no picture with sound or once it turns on, the TV will shut...
I have a Samsung HLP5474WX/XAA. The ballast was replace 2 months ago. I just installed the lamp, i notice green flashing occur on the LAMP when i turn it on. The tv takes 10 to 15 second to turn on the picture, the sound as soon as i power up i can hear it. Any advice??
Mar 18, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
