Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet dryer
Dryer "control locked" light on and dryer will not work. Tryed unpluging it for a few minutes, tryed punching all the buttons and moving the cycle dial to all positions and punching end of cycle button. So far no luck.
    Genius:
  • 1,028 Answers
Look for a button with lock symbol beside it press and hold button 3-5 secs lock light should go out and control resume operating
Posted on Aug 12, 2008
SOURCE:
Whirlpool duet dreyer control lock On --can't program dreyer
try unplugging for a couple of minutes and it should reset to factory settings.
Mar 07, 2018 | Whirlpool Washing Machines
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer does not run. The control lock light stays on even after I hold down the end of cycle button for over 5 seconds and/or unplug dryer for over 15 min. The light comes on when door is...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I own a 4 yr old whirlpool duet dryer and controls locked light came on and can not get it to go off
Look for the End of Cycle button at the extreme right hand side of the console then press and hold it for 3 seconds or until the Control Locked light turns off. The instruction is actually printed right below the button. The control lock is a safety feature of the dryer to prevent settings manipulation during the drying cycle.
Unplug the dryer for at least 15 minutes to reset the central control unit if the control cannot be unlocked using the End of Cycle button. Let us know if it's still cannot be unlocked even after the machine is unplugged.
Apr 11, 2010 | Whirlpool GEW9250 Electric Dryer
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I...
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I plug it back in the control lock light come back on. Whirlpool Duet gew9250plg
Aug 05, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
296 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
