Question about Philips Magnavox 27MS343S 27" TV
Wont turn on
Tv wont turn it was given to us so no manual
  • chewney92 Aug 12, 2008
    tv given to me wont turn on
Snakehead is a ******* **** HIM!!!!!!!!!!
Posted on Jul 18, 2009
    Genius:
  • 1,074 Answers
If you are not a tech then have a qualified tech repair your tv your problem could be in the power supply ,horizontal circuit .or the micro.good luck.
Posted on Aug 19, 2008
Red on tv wont come on
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations.
Aug 13, 2014 | Samsung LN46B640 LCD TV
Tv wont turn on
Hello
If there is no power light on the front panel of your TV, ahen you switch it On, the power supply to your tV should be troubleshooted. You haven't given its exact model number here. If so I might send some more details that may help you. Usually, power supply regulator boards fo these type of TVs will have no repair to it, and should be replaced as card basis. OK
Feb 07, 2012 | Zenith Televison & Video
WONT DRY,DRUM WONT TURN
This sounds like the motor that drive the drum has packed it in could be the capacitor or the centrifugal switch cant say with the amount of info given. I am quite sure it is with the motor as manually turning it is assisting with the start up of the motor
Aug 18, 2009 | GE Profile Harmony DPGT750EC Electric...
Can't program emerson tv control volume or to turn it off.used all codes.not working.all other controls work. Thanks,ladybrd
If this is a new Emerson flat panel lcd tv from Walmart, there is a chance that the remote just wont work. I've had problems with these Emerson's often with all dish network remotes. you can try doing a search on the remote itself though. Turn your tv on manually, then push the tv button on the remote and hold it until it flashes, then hit the tv power button on the remote, then push the up arrow button continuously (not to fast though) until the tv turns off and then push the # button (below the 9 button) and the remote should work. There are some new tvs' that these remotes just wont program. I hope yours works.
Jul 22, 2009 | DISH Network IR Remote Control
T.V. has had problems turning on for a while, now wont turn on
you dont need to buy a new board they cost about 300-400 dollars--- they have refurbished boards around 100 -- look online at
partsstore.com
Jan 19, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv wont turn on
Check the connection properly once again. if the connection are checked and you are sure there is no roblem then the switch or the power board may have gone bad and needs a repair.
Thanks
Jan 03, 2009 | Mitsubishi WS-65819 TV
Blue,red,green lines on top of screen for couple months. Now tv wont work.
The foldover is because of a bad capacitor in the vertical circuit. Given the "new" sympotom of a dead set, I would suspect that the vertical IC has failed. This should be a relatively simple repair for a TV shop. If you wish to attempt a repair of this yourself, update this and confirm your model number and I'll post more details and instructions.
Dan
Nov 10, 2008 | Philips 32PT5441/37 32" TV
Red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Jul 24, 2008 | Philips 37PF9631D 37 in. LCD HDTV
Tv is on stand by mode and wont turn on
how long have you had your tv, and what i had found out is that after replacing the power supply board my tv went out a second time but i had gotten a warranty and then another power supply board was replaced and it would not come on, for 2-3days, so everyday i would just keep on pluggin it up and one day it came back on and i havent turned the tv off yet, what i was told by the tv repair man was that i needed a picure tube, and he said sony knows these tv has alot of problems, i tried contacting sony but was given the run around, i just wont by sony products anymore as they dont stand behind there product
Mar 15, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Philips Magnavox 27MS343S 27" TV Logo
162 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
