Question about Motorola Mobility E51 MD7161-2 Twin Cordless Phone
How do I set the Prerecorded Greeting?
Does anyone know how to reset the answering machine's greeting back to the pre-recorded greeting? Also, any quick tips to set the time and date?
Thanks again!
    Sergeant:
  • 152 Answers
Press delete while reviewing your announcement.The system will use the prerecorded message until you record a new one.
Setting the Clock
NOTE: A flashing
"CL"
in the message window indicates that you must set the correct
day and time at the base unit.
1.
Press the TIME button. The system announces the time and day of the week,
followed by
"To set day and time, press TIME/SET."
2.Press the TIME
button. The system announces the day.
3.Press the CHANGE
button repeatedly until the system announces the correct day.
4.Press the
TIME
button to save the new setting. The system announces the setting.
5.Press the
CHANGE
button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6.Press the
TIME
nnounces the minute.
7.Press
CHANGE
to advance the minutes one at a time. ­OR­ Press and hold the
CHANGE
button to advance the minutes in increments of 10.
8.Press the
TIME
button to save the new setting. The system announces the year.
9.Press CHANGE
to advance the year one at a time. ­OR­ Press and hold
CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME
. The system announces the clock setting
Posted on Aug 12, 2008
SOURCE:
How do i record a greeting message?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG1033S
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 26 of the manual for detailed instructions on how to operate the answering system on your phone.
Basically that section of the manual reads as follows:
Greeting message
When the unit answers a call, callersare greeted by a greeting message.
You can record your own greeting message or use a prerecorded greeting message.
Recording your greeting message.
You can record your own greeting message (max. 2 minutes and 30 seconds).
If you do not record a greeting message, a prerecorded greeting message is used.
1 Press the MENU button.
2 Scroll to ANSWERING DEVICE using the up and down arrow keys and then press OK.
3 Scroll to RECORD GREETING then press OK.
4 After the handset beeps, speak clearly about 20 cm (8 inches) away from the microphone.
5 To stop recording, press the OK button.
6 Then press the OFF button.
Using a prerecorded greeting message.
If you erase or do not record your own greeting message, the unit plays a prerecorded greeting message for callers and ask them to leave messages.
Playing back the greeting message.
3 Scroll to PLAY GREETING then press OK.
4 Then press OFF.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 13, 2011 | Panasonic KX-TG1033S Cordless Phone
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
How do I change the greeting message?
You can record your own greeting message (max. 2 minutes) that is played when the answering system answers a call. If you do not record a greeting message, a prerecorded greeting message is used. 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm (8 inches) away from the MIC. 4 To stop recording, press {STOP}.
Mar 08, 2011 | Panasonic KX-TG5632 Phone
My answering machine message is out dated and needs to be changed how do you do it?
message
message (max. 2 minutes). If you do not
1 {GREETING REC}
from the MIC.
Feb 11, 2011 | Panasonic KX-TG6021M Cordless Phone
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
use a pre-recorded greeting message.
message
message (2 minutes max.).
1 {GREETING REC}
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
are greeted by a greeting message. You
message.
message
seconds). If you do not record a
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
5 To stop recording, press {OK}.
6 {OFF}
message
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
Retrieve orginal factory greeting after being erased
Hello folks, I offer no guarantee on this but it worked for me.
1. record own greetings >menu>answering device> record greeting>then after recording own greetings press OK
2. Erase own greeting just recorded >menu>answe...device>erase messa...>erase greet...>Ok
3. Then try Menu> answering device>play greeting....voila. Prerecorded message plays.
Hope This helps.
Jun 01, 2009 | Panasonic KX-TGA101S Cordless Handset
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
message
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Nov 21, 2008 | Panasonic KX-TG9331T Cordless Phone
Lost phone greeting
If you press the Greeting Check button and only the pre-recorded greeting plays back, The other greeting has been accidentally erased.
Aug 24, 2008 | Panasonic KX-TG5632 Phone
Motorola Mobility E51 MD7161-2 Twin Cordless Phone Logo
341 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Clyde Hanson
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
