Question about Hoover U5507900 Elite Rewind Bagless Upright Vacuum
Air flow indicator stays activated after filter has been cleaned. Brush spins, but very little suction. Dirt doesn't spin in cup.
  • bcarde Aug 17, 2008
    I have the same problem on the same vacuum and nothing is clogged
  • glennie2 Sep 28, 2008
    Same problem. I have dissassembled completely and there is no blockage
    but airflow indicator still snaps over and no vac at brushes but lots on
    end of hose.
    Novelist:
  • 97 Answers
Your vacuum is clogged. Check all of the air pathways, hoses, etc. The most common places to check are anywhere there's a joint in the airways, and also directly behind the brushroll.
-R
Posted on Aug 13, 2008
Shark navigator lift away turns on but no suction
Hello, this is Ava with Think Crucial.
It seems that there may be something blocking the airway. To fix this, please make sure to unplugged the unit from the power before performing this.
There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, keep reading for other options to fix the suction.
If both your foam filter and felt filter have not been cleaned in the past month, this may be why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
If none of the other solutions worked, your motor may be bad. You would need to check with Shark about this.
If your need to replace your Shark parts such as filter, belts or hose, you can also order replacement parts directly to us. You can check our online store in this link: http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 17, 2016 | Shark Vacuums
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Vacuums
"Power Brush" attachment doesn't work
When my hover suffered a similar issue i found the problem to be a little stone caught in the part you described as a water wheel, however later i found that one of the connecting hoses from the front of the hover had a little blockage , later, i actually washed the filters and left them to dry over night wrapped in a towel on a warm heater, it was back to normal , the last hover gave in as the motor started to slowly give in , it could be this
Mar 15, 2014 | Vacuums
Loss of suction o=with hose tool
Hose or tool is probably clogged. Is this an upright? Bagged or bagless? Have you changed the bag and filters? Cleaned out the brush and hose that goes from the brush area to the collection bag/cup? The only reason for a vacuum cleaner to lose suction but still work is a clog or dirty filter which blocks the air flow. Follow the air flow from the brushes to the bag/dirt cup. If the machine is bagged, change the bag. I use another vacuum cleaner to do this.While your at it, might as well change the belt.
Nov 15, 2011 | Hoover Vacuums
My bissell vacuum has no suction. the power works and the brush turns but I have no suction. what should I do?
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Sep 25, 2010 | Vacuums
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Spinning debris in cup
If the 2 stage filters inside the bin chamber have not been washed then they will need to be - they sound like they are clogged or somewhere there is dirt which is blocking up the system. Also check the side part duster to ensure that the airways are not clogged with dirt.
When you turn the machine on, have a look to see if the moving brush is actually spinning. Then switch off and remove the base plate to see if anything is clogged in the main dirt channel which is usually located on the left or right hand side - where the dirt goes in from the floor.
This model is based on an Electrolux model in the UK which can be notorious for clogging dust. Check the hoses at the bottom where they come from the main dust bin and the air ways to check no dust is stuck.
Apr 18, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Carpet cleaner not doing too well
there is a dial on the side of the housing move this to tools this diverts the suction from the floor nozzle to the hose,. .
the brush only rotates slowly.
If this dose not work check red lint filter, .this is in the back corner of the tank lid ,
On the turbo brush there is a sliding swicth ,this diverts the suction from the nozzle of the attachment to the attachments brush
Oct 27, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Hoover U5507900 Elite  Rewind  Bagless Upright Vacuum Logo
424 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
