Question about Sony NWZ-S615F Walkman Video MP3 Player
Digital media player
I got this sony media player 4 months ago. No problems before today. It just stopped dead. Will not turn on and will not charge when I plug it in.
Help
Jill
  • andrewray Aug 13, 2008
    when i took the battery out and then plugged it in it came on i think it might be a bad battery
  • 3 Answers
Actually, I thought it was a battery problem too...but it wasn't. My b105f has a special 3.7v soldered in battery...so it isn't coming out. When I loaded the new firmware (v 1.1) it did great after a reset.
Posted on Nov 30, 2008
  • 8,596 Answers
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Posted on Sep 14, 2008
The screen has gone blank!!
Charge the Walkman fully. To charge the battery of the Walkman fully keep it plugged in to the Computer for 4 hours.
Reset the Walkman by pressing the RESET button that is located at the bottom.
You can use any sharp pointed object to press the reset button.
If the issue persists then Walkman may require service.
Jul 21, 2010 | Sony NWZ-E438F Digital Media Player
Sony mp3 wont turn on or charge
Hi ramoncuaya,
There seems to be something wrong with the device itself, two weeks is too little of a time for it to malfunction. If it is still covered by the warranty, take it to a service center. But it is also not advisable to leave it lying around non-operational for over a month.
Nov 30, 2009 | Sony Audio Players & Recorders
My Sony WALKMAN mp3 player won't charge
If it is a NW-A1000 I have a copy of the service manual please download it from HERE from deposit files..will be active until 29th November 2009, let me know if you need it for longer.
Goto page 9 section 4 TEST MODE.
1. Press HOLD to put the player in hold mode.
2. Hold down LINK and press in order UP, DOWN, OPTION, UP, DOWN, RIGHT, LEFT, RIGHT, LEFT, LEFT, PLAY/PAUSE, OPTION.
3. Press HOLD to turn hold off. You will now be in test mode.
4. Press RIGHT to display menu items
5. Press the UP,DOWN to select the POWER
6. Press RIGHT to select V CHK
7. Press the PLAY key START is displayed and all the power lines will be started.
TP9027: 1.10 ± 0.05 V T
P9023: 1.3 ± 0.1 V
TP9026: 1.8 ± 0.1 V
TP9031: 3.0 ± 0.1 V
TP9018: 3.0 ± 0.1 V
TP9028: 3.3 ± 0.1 VT
P9024: 5.0 ± 0.2 V
You can check these on the main board to see it all are present if one is missing this will be why your walkman wont hold any charge.
LOL
Sep 23, 2009 | Sony Audio Players & Recorders
Sony Walkman NW-A808 MP3 Player stopped working. My player stopped mid song, wont turn on, reset or charge in fact it is completely dead, it is 17 months old.
please install the firmware update to resolve the issue.
http://esupport.sony.com/CA/perl/swu-download.pl?mdl=NWA808&upd_id=3721&os_id=29
Steps to download and installed are mentioned on the page itself
Sep 22, 2009 | Sony Walkman NW-A808 MP3 Player
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Dead battery
Charge the battery using the supplied USB cable. The salesperson meant that the battery would last for years before it will no longer take a charge and need to be replaced.
Apr 06, 2009 | Sony NWZ-E438F Digital Media Player
Sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
Dec 29, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
TomTom DIED?
Call TomTom 1-978-287-9555 4 months is really early for the unit to break.. thats even before their 180 day warrenty period.. call them today and return it!
Apr 30, 2008 | Tomtom GO 300 GPS Receiver
Dead zen
IDK my BFF JILL or ROSE, no IDK for real, but if u got a warranty i'd send it back. :§
Apr 21, 2008 | Creative Labs Zen Digital Media Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
107 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
