Question about Sony Handycam DCR-TRV38 Mini DV Digital Camcorder
Tape loading Camera has been working great for YEARS, until all of a sudden I couldn't load a new tape. Upon opening the case & inserting the tape, the mechanism wouldn't load it up & move down into the camera body as usual. Any ideas? The rechargeable battery still shows power - is there something else pooped out?
  • dareeder Aug 12, 2008
    Nothing bent or loose or odd - the door pushes shut as usual on the tape, and then pops open 15-20 seconds later (instead of loading into the camera). Thanks for whatever you can suggest!
  • Tim Babcock
    Tim Babcock May 11, 2010
    Check for any bent parts, any loose springs or parts or anything that doesn't belong in there.
  • Sony Master
  • 2,794 Answers
You should take it into a camera shop and have them inspect it. Those assemblies are pretty detailed. They have the tools to fix the problem.
Posted on Aug 12, 2008
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Dec 16, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Camera is a JVC GR-DF470 Video Camera. Problem is UNIT IN SAFEGUARD MODE EJECT AND REINSERT TAPE ERROR 03. I have done this and problem still remains.
I have the same model of camera and the same problem has occurred after two years of use. I am not sure why it happens but checking on other web sites, it may have to do with tape tension and the brand of tape. Up to now, I was using Sony and JVC tapes which worked fine but a recent purchase of TDK tapes seems to have caused this problem.
My fix was to take the tape out and then manually wind the tape a couple of turns by inserting one flat blade screwdriver in the tape lock tab (bottom middle of tape case) and using another to wind the tape. This appeared to fix the tape tension and after loading it back in, the tape and the camera worked fine.
Hope this helps.
May 05, 2008 | Cameras
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Canon MVX200 will not load dv tape
The "remove Tape" error message on Canon DV camcorders is a general message meaning something is not correct with the tape transport system. These are miniature precision mechanisms and It could be anything from dew sensors to head motor, capstan drive etc. If the cassette drawer closes OK with no tape inserted then the tape sensor/ end tape sensor is operating. With no tape inserted the head drum does not run when the drawer closes but it does with a tape present. Does the head drum start up when you load a tape or is there no noise at all? If the head runs then it is possible the capstan is not starting or is jammed. If the head does not run then the cure will be either extremely tedious and delicate or very expensive. These units do not dismantle easily so unless you have some experience with this, or are willing to take a risk, then I would not recommend it. However, without such action you may have to write-off the unit anyway. Canon's repair charge will exceed the camera's value unless it's still under warranty. Your best option would be to find a local repairer that is willing to look at it, but I wouldn't be too optimistic .To some, this error message is a major issue when deciding to buying canon dv cameras. However, they are great little cameras and treated kindly will give many hours of excellent service. Don't store the camera with tapes loaded. don't subject it to sudden temperature changes or excessive vibration. Store it in a dry protected atmosphere and refrain from taking it onto the beach (salt AND sand !!!!) when on holiday etc.
Dec 17, 2007 | Canon MVX200 Mini DV Digital Camcorder
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Tape ejects just after insertion
the end-of-tape optical sensor is at fault. either it is very dirty, has failed or something else is detecting end of tape. many VCR's now will auto-eject the tape upon end of tape detect
Dec 19, 2006 | Mitsubishi HS-U760 S-VHS VCR
Sony Handycam DCR-TRV38 Mini DV Digital Camcorder Logo
64 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
