Question about Kenwood KAC-848 Car Audio Amplifier
Kendwood kac-848 audio problem
When i hook up my kenwood to my two kicker c12's it works at first but then when the bass hits hard, it cuts out, and i dont know why, what can i do to fix it, and how much will it cost?
  • 631 Answers
Are you sure you have the speakers wired to present a safe load to the amp?
Posted on Aug 12, 2008
What is the rms outpur of my kenwood KAC 848 amp
rms at 4 ohms is 50x4 in 4 channel mode if your in 2 channel mode then its 150x2 if at 2 ohms then it would be 4 channel 75x4.
Jul 28, 2010 | Kenwood KAC-848 Car Audio Amplifier
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Power from the kenwood 9103D to the Kicker comp 15's is on n off
Most times I hear of people turning up the volume on a head unit and cutting off on the amp it tends to be wired to a speaker with the wrong impedance. I googled kicker comp and got tons of different models, not to mention almost all of them were 250 watt rms. That amp is 900 watt RMS at 2 ohms. If you only have 1 woofer, you can't possibly wire it wrong being all the subs I've seen in the results were 4 ohm. If you are using just one though, you should get a larger speaker, both 2 ohms and 1000 watt rms to prevent distortion. I'm afraid I can't answer your post without further information on the sub you are using.
Nov 20, 2008 | Kenwood KAC-9103D Car Audio Amplifier
Kenwood kac-7202 wirng 4 subs
look at the Z [impedance] specs for the amp. Look at the Z for the speakers. You may eventually have to wire them in a series-parallel config or risk blowing your output transistors.
Due to the utilization of so many drivers, your power demands are limited. The more drivers you utilize, the more volume loss. Bass response requires a lot of power (W) in which to drive.
Do not worry about paper or polyprop/carbonate structures... focus on your impedance issue or risk frying the output transistors in the long run [thermal runaway].
Oct 15, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood KAC-9152D Car Audio amp
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Sep 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-848
You have blown outputs , faulty channels. What kind of amp do u have and what were u running to it? Most likely a bad amp, u might need a new one.
Jan 24, 2008 | Kenwood KAC-848 Car Audio Amplifier
My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
Dec 30, 2007 | Kenwood KAC-X1R Car Audio Amplifier
Schematic
Try manualsparadise.com or go to the Kenwood web site and look in the support section.
Dec 18, 2007 | Kenwood KAC-848 Car Audio Amplifier
Amp Turns on... then off
unplug all speakers and see if it still into protect .If unit powers up normally without speakers , then hook up a temporary speaker directly to speaker out to see if you have output.If it works .Then check speaker cables and speakers for shorts.Also make sure you have good ground and main power and standy are present.
Nov 30, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Car Audio & Video Logo
83 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
