Question about Sharp AQUOS LC-32D43U 32 in. LCD Television
Lcd model # and error msg
Error message: no input selection available
LCD model #: 289LC32D43U
Please let me know what the next step is. Thanks!
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
My acer 19in LCD monitor goes blank after initial startup and msg "Input not Supported" appears. Startup msg are shown but once Windows starts, this error appears. I have tried to adjust the...
May I ask to what you mean by "adjust the resolution in safe mode, this has not helped"?
Did you set it to native resolution of this monitor? Unless it has problem inside the monitor, try it with another PC also.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 08, 2010 | Acer AL1916W 19" LCD Monitor
There is a flashing message on teh screen that says, " This function is not available now."
I get this message when I've selected an input such as 'HDMI1' or one of the component inputs and try to change channels with the TV remote instead of the cable remote.
May 01, 2010 | LG 42LG30 42 in. LCD HDTV
Display AL 1717 input not supported
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there!
This usually happens when switching from a CRT to an LCD monitor. If your monitor is new and you are connecting for the first time, reconnect to the old monitor, set the resolution to its lowest setting (usually 800 x 600), shut the machine down, plug in the new monitor and boot the desktop to watch the screen.
If you are unfamiliar with how to change the resolution, here are the steps to do so:
1. Right-click on the desktop
2. Select Properties
3. In the Settings tab, click and drag the Screen Resolution option to its furthest left position.
4. Click Apply and OK.
If this doesn't fix the problem, it's likely that there is a driver conflict. If you still have the old monitor, or if you have another CRT available, boot up again when connected to the CRT and perform the following steps to remove the old drivers from the machine:
1. Click Start
2. Right-click My Computer
3. Select Manage
4. Select Device Manager
5. Expand Monitors
6. Right click on the monitor you wish to uninstall and select "Uninstall"
7. If there are any other entries, uninstall those, as well.
Then shut your machine down, plug in the LCD monitor and boot the machine.
If the above mentioned steps don't help, try switching the type of cable used to connect the monitor to the desktop. If you are currently using a VGA cable, try switching to DVI (depending on how old your graphics card is this option might not be available). If using DVI, try switching to VGA.
If the LCD monitor manages to work, I would recommend you verify the proper drivers are installed. To do this:
1. Click Start
3. Select Manage
5. Expand Monitors
6. Right click on the monitor you wish to update the drivers for and select "Update Driver" (you will need to be connected to the Internet for the automatic update to work)
7. Select "Yes, this time only" and click Next
8. Leave the default option selected on the next screen and click Next.
If the automatic driver update finds no match for the hardware, you may need to download the driver and install it manually. Click HERE to download the driver for your monitor.
Save the file to your desktop and extract the file to your desktop. In Device Manager, right click on the Acer monitor and select Update Driver.
Select "Yes, this time only" and click Next.
Select the Advanced option on the next screen and click Next.
Check the checkbox next to "Include this location in the search:"
Click Browse.
Minimize any option currently expanded and search for the recently extracted folder underneath "Desktop".
Expand it and select the folder inside.
The OK button should now be available. Click OK and click Next.
The driver should install and your monitor should function normally from that point forward.
If none of those options work, you might want to think about opening a support case with Acer or returning the monitor for one that is comparable.
I hope I was able to help you! If you have any questions, please feel free to respond.
Aug 30, 2009 | Acer AL1717 17" LCD Monitor
Cant change my sanyo 6650 mobiles incoming msg font
here i hope this helps you Display Settings
Changing the Text Greeting
The text greeting can be up to 15 characters and is displayed
on your phone’s screen in standby mode. You may choose to
keep the phone’s default greeting (“Sprint”), or you may enter
your own custom greeting.
To display or change your greeting:
1. Select > Settings > Display > Greeting > Custom.
2. Enter a custom greeting using your keypad and press .
(See “Entering Text”on page 39.) (To erase the existing
greeting one character at a time, press .
To erase the entire greeting, press and hold .)
Changing the BacklightTime Length
The backlight setting lets you select how long the display
screen and keypad remain backlit after any keypress is made.
To change the Main LCD or Sub LCD backlight setting:
1. Select > Settings > Display > Backlight.
2. Select Main LCDor Sub LCD.
3. Select Always On, Dim Only, or a preset length of time.
To change the Keypad backlight setting:
1. Select >Settings>Display>Backlight>Key.
2. Select Always Off or a preset length of time.
Note: Long backlight settings affect the battery’s talk and standby
times.
Note: The Always On setting returns to the previous value the next
time you turn on the phone.
Your Phone’s
Please rate this solution thanks...
Jan 30, 2009 | Sanyo Katana II (SCP-6650) Cellular Phone
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Sharp AQUOS LC-32D43U 32 in. LCD Television Logo
159 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
