Question about Whirlpool Washing Machines
Retiming the gearcase on whirlpool model lsq8500jq1
  • jerrypicon Aug 12, 2008
    Do the gears in the gearcase have to be in a certain position?
  • Mike Durland
    Mike Durland May 11, 2010
    what do you mean by retiming? I have rebuilt hundreds of these transmissions and I am not sure what you are referring to.
  • 481 Answers
The only thing that needs to be aligned is the agitator rack. it has a mark or sometimes a hole on the center tooth. it hat to line up with the center tooth of the opposing gear. there is only 5 teeth on the other part so it is easy to line up the center tooth to the agitator rack.retiming the gearcase on whirlpool - dbff82c.jpg
Posted on Aug 12, 2008
SOURCE:
How i could replace transmision on whirlpool washer model#lsq9650pw
The following link explains step-by-step how to replace the gearcase (transmission) in a Whirlpool top loader:
http://www.fixya.com/support/r699497-replacing_gearcase
This is not a difficult repair, but it can be tedious. Take you time and read through the link provided. If you have questions, please let me know.
The part number is 3360629. A replacement gearcase can be purchased at pcappliancerepair.com for about $145. This was the cheapest price I could find. Other sites you may try are:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
I hope you find this information helpful.
NOTE: These gearcases are to be shipped in the UPRIGHT position. The instructions are on the shipping container. However, if it does get shipped lying down, sit it upright and allow it to sit for about an hour to allow the oil to settle back into the bottom. Do not forget to puncture the breather hole before installation.
Sep 04, 2009 | Whirlpool LSQ9650PW Top Load Washer
Top load LSR5132PQ whirlpool machine - mine is leaking oil - is this a problem with these machine?
Leaking oil can be an issue if the problem becomes worse. This is can be an indication of a gearcase (transmission) that may be going bad. However, I have seen washers in this condition for months (years) and still function. Sometimes, excess oil will come out through a small breather hold on the top of the gearcase. Ultimately, if the problem continues to get worse, you will need to replace the gearcase.
I am posting a link that explains how to replace the gearcase if you decide to repair the unit yourself. I'm also posting it so that you have the knowledge on how to remove the washer case so you can inspect the interior:
This is what you need to do for now. Remove the washer casing, using the instructions I have provided, and take a look at the interior cabinet walls. If you see oil spray marks all around the interior, replace the gearcase. If the oil you are seeing is minor in nature, clean up and any spills/drips and place a clean sheet of cardboard under the washer so you can monitor how much is leaking. A tell-tale sign that the gearcase is beginning to go bad, is slow spin speeds and/or grinding noises. The gearcase also has a series of nuts that hold the upper pan to the case. You may also check to see if all these nuts are tight and not causing leaks. You will probably need to remove the gearcase in order to access them, however.
Pcappliancerepair.com has some excellent exploded view diagrams of your washer that you can use for reference. Just type in your model number and locate item 9 under the "Brake, Clutch, Gearcase, Motor and Pump" heading. The gearcase sells for about $144. You can also check searspartsdirect.com, appliancepartspros.com, or repairclinic.com to see if they carry the part any cheaper.
NOTE: If you DO order this part, make sure that the container is shipped upright. There are container markings on the box that indicate this, but those instructions sometimes get ignored. If the container is laid down, the oil can leak out through the breather hold on the gearcase.
This is not a difficult repair as long as you follow the steps provided. If you wish to pursue it (if needed) and still have questions, please let me know. I hope you find this information helpful.
Aug 04, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool gear case won't come out
did you take the agitator out of the washer it has a bolt that holds the agitator to the gearcase. if you did sometimes you have to take a screwdriver and tap the shaft of the gearcase from inside the tub
Dec 20, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer was in spin cycle,theen something broke ,lots of noise ,i think its a belt ,how can i tell?
Topload whirlpools do not have a belt. There is a 'coupler' between the motor and the gearcase that has most likely failed. The coupler consists of a plastic three pronged gear, one on the motor, the other on the gearcase with a rubber piece in between. You can check the coupler by tipping the machine back and looking at the connection between the motor and gearcase. If you require assistance in replacing this part, let me know.
Regards,
reg501
Jul 21, 2008 | Whirlpool Washing Machines
Roper by whirlpool model # RAX4233PQ0
i assume that's a top load and not a front load as pictured..ck wiring connections to motor try turning coupler between motor and gearcase by hand if locked remove pump(2 clamps from motor) try again if turns free clean pump if not gearcase ..if turns free with pump attached and wires look ok suspect timer
Jun 20, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
49 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
