Question about Rowenta Powerglide DM273 Iron
Rust coming from iron
When i uuse the steam buttom to get more steam rust comes out and gets on my clothing. How do i keep that from happening Do I pour something in the water opening Marilyn B
  • 2,794 Answers
See if you can get a hold of some CLR (Calcium, Lime, and Rust). It's a cleaner most drug stores and hardware stores carried in the states. Pour that into the system and then flush it out. Make sure the CLR isn't in the iron before you use it again.
Use filter water in your iron in case there is rust or sediment in the tap.
Posted on Aug 11, 2008
Why is there brown thick liquid coming out or my iron,when I use the steam
Very dangerous situation. Rusted parts inside give the water that particular colour. Change the iron asap (as soon as possible), otherwise all your clothes will be the same colour.
Sep 11, 2017 | Irons
My brand new Hamilton Beach steam iron is shooting out rust on my clothes. How can I get it stopped?
Clean it.
Tip & How-To about Irons
Cleaning a Laundry Iron Get some CLR descaler and mix it to the directions. Turn the iron on and set it to steam. Turn the iron off and put the CLR into it. When it has cooled a little, sit it faceplate down in an oven proof dish. Leave it over night. The CLR will drip through and sit in the dish cleaning the inside, and the topside of the soleplate. The next day, fill with water and shake upside down to empty any remaining CLR and scale through the fill hole. Keep filling and shaking to empty until the water comes clean.
If you don't want to use CLR, you can use white vinegar undiluted.
Posted by Andrew... on Mar 18, 2016
Cleaning Laundry Iron
Aug 07, 2017 | Hamilton Beach Irons
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Steam keeps coming out rusty, leaves marks on clothing. model ir5410
The iron needs to be taken apart and cleaned. If it gets rusty again, it's a poorly designed iron and you'd be better off with a replacement. Steam Irons should not rust!!
May 05, 2009 | Rival Irons
Rowenta Effective
The rust spot are probably caused by iron in your tap water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete, fill again with clean water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Another option is to use distilled water in your iron. Distilled water has all the minerals removed.
Good Luck!
Aug 11, 2008 | Rowenta Powerglide DM273 Iron
Rust
A few cheap n easy ideas I hope will help you...
  • You could try using a car radiator flush treatment such as rust & scale inhibitor to flush the water tank.
  • Fill water tank with Coca-Cola . Let it soak at least overnight and rinse out thoroughly.Think im crazy? Leave a old coin in a glass a coke for a few days and see what happens!!
  • Refrain from using tap water to fill the iron. Use distilled water ,it's has less of the impurities that cause rust and other metal-oxides forming
  • If all else fails use a small spray bottle of water on the clothes that are at most risk of being soiled.
That way you can add fragrance oil or other things to the water that would normally get boiled off /or pollute the water tank :)
May 26, 2008 | Black & Decker Steam Xpress AS250 Iron...
Brown gunge and white deposits keep coming out of the steam holes on the sole plate. We have tried de-scaling but it has had no effect. This iron has had very little use since we bought it about 18 months...
Try filling full-strength white vinegar instead of water. Then allow to steam out on scrap cloth. The white deposits are likely to be calcium. The brown gunge may be rust. When the deposits are minimized, use only distilled or bottled water from then on.
Mar 15, 2008 | Rowenta Perfect Iron
Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Nov 15, 2007 | Irons
Rowenta Powerglide DM273 Iron Logo
354 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
