I don,t have power to my printer. It is connected with the computerand the computer works. I have checked all the plugs and they are all connected. What would the problem be?
  • 1 more comment
  • isntax2 Sep 01, 2008
    I have no power to my printer - all plugs are in place, computer is on, green light on power supply cable connect is on. Printer will NOT turn on. Have tried reattaching all cables, restarting computer, etc.
    What is the problem?? I have had this printer for less than one year.
  • dr_jac23 Oct 14, 2008
    i tried changing the fuse on the power supply board (8A fuse), since it was blown... but everytime i try to connect everything back on it blows the power off again... there must be some sort of overload. i discovered though that as long as i dont close the printer cover the printer turns on. as soon as i close the cover, it blows the circuit breaker for me, and the fuse. I wonder if its something to do with the switch in the Printer Cover, or anything the switch triggers..
  • Anonymous Oct 14, 2008
    the printer is plugged in but no power. after plugging the printer in it cycles itself without lighting up the menu led. than nothing happens after that
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Failed power supply; either internal or external, depending on printer make, model and type.
Posted on Aug 12, 2008
My scanner is plugged in but when I try to scan a document it says my scanner is not responding
If it is your first time using your printer, then you need to install the driver for it to work.
If you have used your printer without any problem before then, there are two possible reasons why your printer/scanner is having that issue:
1. Connection error
2. Driver problem
First thing's first. Restart your computer and your printer. there are times that computers and printers just need a restart for it to work. Yes, it's strange but it's how things work with machines. They need rebooting to work smoothly.
If rebooting your computer and printer won't fix the problem. Here are the things that you can do.
1. Connection error:
a. Turn off your printer and turn it back on. Try scanning, if no go.. proceed to step b.
b. Unplug your printer from your computer and unplug it's power cord and press and hold the printer's power button to 5-8 seconds to completely drain the power. Plug it back in to the wall outlet leaving the connection between your computer and the printer still unplugged. wait until your printer completely turns on. Plug it to your computer and do the scanning process.
If all steps above don't work, then you need to check the driver.
Uinstall the driver of your computer by going to the control panel. After uinstalling it, then reinstall it by using the dvd that came with your printer. Follow the on-screen instructions and try scanning. It should work.
If it doesn't, please reply to this thread.
Thank you for using
Carlo Adrian
Nov 14, 2012 | Dell Photo 926 All-in-One Printer
HP M2727 printer has FLASHING attention and ready lights
leave printer on, and unplug the power supply, then wait10 min. plug it back in, this should reset the printer, you might have to do this again and unplug any connections to your computer, wait and then plug in printer with power off and plug in connection to your computer, then turn on printer,, check your ink levels when you power up. if ink levels are low ,you could get this error. if this don;t work go to your printers website and check there solutions or you might have to call them.
Oct 02, 2012 | HP CB532A - LaserJet M2727NF All-in-One...
How to connect routerlogin
1.Connect your computer to the router using Ethernet cable. Connect the modem with the router and computer also.
2.Plug the modem, router, and computer in their respective electricity wall outlets. Turn on the cable modem and wait for it to boot. Turn on the Netgear router and computerand let them boot.
3.Open a web browser and type "" into the address bar and press Enter. It will open up the login page.
Aug 22, 2012 | NetGear Computers & Internet
I have a Lexmark X4550 printer. Recently, when I try to scan it asks me to enter a PIN. I don't recall ever setting a PIN. How can I reset it and/or set my printer to not require it?
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 31, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Mx7600 error code 5c20 Problem
Please remove all cartridges and print head. Using a moist cloth clean the golden contacts on Print head as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the Print head and cartridges.
Now see if its working fine.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX7600 Office All-In-One Printer
I just bought a new HP computerand I had my files transfered from my old computer. Now my HP 6300 printer will not print. I think the printer software is gone. What can I do? I moved recently and do not...
Don't worry. You do not need the HP disk for the software and drivers. All you need to do is go to the HP website and download the latest drivers and software for your printer. If you have any other questions feel free to repost in this thread.
And please, don't forget to rate me!
Best of luck to you!
Jul 07, 2011 | Office Equipment & Supplies
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a x6650 series printer and I am trying to scan a document but it keeps telling me that it can't retrieve my application list. However it has already scanned something for me today and...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect it from your computer. Reboot your computer. Unplug and re-plug your printer from the power source to reset it. When the printer turns on, reconnect it your computer. Try to scan again.
If the printer is wirelessly connected to the computer, check the status of the WiFi light. Green light means your printer is connected to your network. Orange means otherwise.
Jun 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Its an 8gb.i had it plugged into the comeputer it
You did not turn it off completely. Press and hold the power button for more than 4 seconds or unplug the power cord. Then try again. If a problem persists, write here again.
Oct 03, 2017 | IBM NetVista PC Desktop
Will the E193FP work with my computer?
I would suggest , check the monitor connections again. Dell flat panels are plug and play and donnot require additional drivers.
Make sure , you have not connected , both the analog (vga cable with a blue connector) and the digital (dvi cable with a white connector) to the back of your computer.
Refer to the the link below , to troubleshoot the monitor
Nov 10, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
53 people viewed this question
