Question about Jl Audio 1000/1 Car Audio Amplifier
Jl amp the power is going to the amp but when i put the remote lead in to turn the amp on it drops the volt down to about 5 but jumps up and down a bit but that only heppens with the remote lead in and it is a 8oamp fuse have bin waiting to upgarde but just have not got round to it the fuse would only blow if i turned it up so it was not any where neer its max when it went
  • 631 Answers
The amp may have blown output transistors and that's why the voltage is being pulled down so far. This should have blown the fuse. If you're using an AGU fuse or there is corrosion, these could also cause the voltage to drop.
Measure the voltage across the fuse holder when you turn the amp on. If the voltage is more than 2v, replace the fuse.
Posted on Aug 11, 2008
Amp cuts off at high volume
Problem could be that you need to upgrade your battery, do the "big 3" wiring by a professional. Get a kinetic 1200 or bigger to replace your stock battery, drive your car for 5 or 10 miles, and watch your amp not shut down. People just dont do the big 3, and they think their stock lead acid will hold 13 volts after the power is shut off. LOL. KINETIC.
Mar 31, 2012 | Jl Audio 1000/1 Car Audio Amplifier
So my jl 500/1 v2 has power and no audio... i get 3 ohm when i use the voltmeter on the amp the sub but no voltage? is this a fuse problem or am i an *** who has no idea how to troubleshoot
Okay lets go step by step. First check and sure you have battery voltage and twelve volt turn on on the remote term. of your amp. Be sure u have a ground also. Next take your speaker leads disconnect them and pop them with a battery, and make sure it pops. I(f that all passes you need to make sure your amp is getting an input signal because you could have a bad rca cable.
Aug 20, 2010 | Jl Audio 500/1 Car Audio Amplifier
Main power and remote lead are both ~12v but when connnected to the amp, main power drops to ~2v while remote lead remains ~12v. the amp got tested and its good. whats wrong?
Due to the power required for most amp's, Most people place either an second battery in the boot of the car or fit Capacitor (power cap)
Which will then allow amp to consume the required power without making main power for the car drop.
Aug 11, 2010 | Jl Audio Class D E1400D Car Audio...
Jl 250/1 amp dies out if i turn on other things
It sounds like you're not getting enough power to the amplifier.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Aug 14, 2008 | Jl Audio 250/1 Car Audio Amplifier
Jl amp
If the power supply feeding the amp is OK, it should have blown the fuse well before the voltage dropped to 5v. What size/type fuse do you have in the power wire feeding the amp?
Aug 11, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Dead amp
You have to go through an authorized dealer to get service from JL. Most good repair shops can repair most problems with them.
Before you send it off, confirm that you have good DC voltage at the remote and B+ terminals.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Apr 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
2000 watt jl audio amp & car battery...
Make sure that you don't have any strands that would connect the remote lead to the constant +12 volts. Also make sure that your remote lead fromt the radio switches off when you shut the car off. If you don't have an aftermarket radio with a remote turn-on lead, tap into the ignition wire to the radio. Let me know what kind of car you have and I can point you in the right direction to get the right wire. Good luck.
-Andrew Hawkins
Apr 08, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead to the B+ terminal of the amp. If the voltage drops below ~11 volts, you need to check the wiring for the B+ line to see where you're losing voltage..
You need to do this as the amp shuts down. Connect the meter and watch the voltage as someone increases the volume.
Dec 31, 2007 | Jl Audio 250/1 Car Audio Amplifier
Wrong connection continuation
If you're installing this in a vehicle with a 12 volt charging system (most automobiles are 12v), I think the batteries may be dead in your multimeter. You shouldn't read anything over ~15v.
When you measure this again, place the black lead on the ground terminal of the amp.
Dec 16, 2007 | Jl Audio 300/4 Car Audio Amplifier
Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
96 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
