2000 Ford Focus Logo
Posted on May 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New spark plugs make ngk bought for 1999 ford focus 1800 could you tell me sparkplug gap please in mm with thanks jim
Dave Quincey
Level 2:
  • Expert 57 Answers
  • Posted on May 04, 2011
 Dave Quincey
Expert
Level 2:
Answers
57
Questions
0
Helped
32514
Points
148
The gap should be 1.3mm They should already be set and resetting can damage the coating.
1helpful
I need the correct gapping for spark plugs on 1999 LR Discovery 2 model???
The earlier 1999 Discovery uses NGK BKR6E plugs or equivalent and the gap is 0.8 mm (0.025"). The later 1999 Discover uses NGK PFR6N-11 plugs or equivalent and the gap there is 1.1 mm (0.043")
2helpful
What is spark plug gap for 2000 ford focus lynx ghia 1.6l gas?
It really depends on the spark plug being used. But if you stick to the origninal spark plug NGK TR5A-10 it is supposed to be gapped a 1.0 mm since Ford has issued an in house service directive to reduce the gap from 1.3 mm (original) to 1.0 mm (present) 0.03936996
Kelly
Spark plugs which are used by the 2003 Suzuki Aerio
NGK SPARK PLUGS: 2002-2005 Suzuki Aerio
NGK BKR5EGP G-POWER PLATINUM SERIES SPARK PLUG, SOLD INDIVIDUALLY -- 14 mm thread, 19 mm reach,16 mm hex size, gasket seat, resistor, solid terminal, JIS height, projected tip, platinum tipped center electrode, trapezoid beveled cut ground electrode, 1.02 mm gap, heat range 5; The best platinum spark plug at an economical cost; Features fine platinum tip that reduces required voltage; Provides faster starts and quicker acceleration; Extremely durable under high heat; Trivalent metal plating offers superior anti-corrosion and anti-seizing properties
.Thank you for using fixya
How to replace spark plugs for 1999 ford contour
to replace spark plugs remove spark plug wire boots. use special sparkplug socket or else you can break the sparkplug. to remove turn ratchet counterclockwise remove all four one at a time, make sure that the sparkplug gap is correct. most plugs come pregapped...read the box it will tell.you. do not overtigheten plug once it has fully seated give it a good snug....if you do one at a time you dont need to mark the spark plug wires. if you mix up the wires your car will back fire which could cause severe internal damage.
2answers
I had replaced spark plugs with NGK BKR6E-11. The fuel economy has gone down dramatically after this change. The plugs I was using earlier were NGK BKR6E-11 and then the mileage has now gone down. Now I am...
You are correct in saying the gap. Call a suzuki dealer, ask for service and as what the gap should be. Your problem is more than likely not having set the gap. Before you change that gap, if you can, measure what is now vs/what it should be. You will need a feeler gauge. Grainger sells the, so des NAPA.
2helpful
3answers
Correct spark plugs to get and gap? thanks
the gap is .060
just get yourself NGK plugs or Denso plugs, they are the best..
2answers
Need spark plug gap for a t reg 1800 focus
what are the spark plug gaps on a ford escort R reg 1.8 xl
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
