Question about Whirlpool LSR7333 Top Load Washer
Whirpool Model# LSR7233BQ2 Top Load Washing Machine. Cold Water not dispensing enough water. Hot water is OK but cold trickles out
  • 5,911 Answers
This is a typical symptom of a water inlet valve that has either a clog, or a bad solenoid. You can attempt to clean by shutting off the water source and removing the hoses from the back of the washer. Check the sediment screens in the water valve (this is where the hoses connect) and clean as necessary with cotton swabs. If its not a simple clog issue, you will have to replace the valve. The folllowing link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
I hope this helps you. If you require additional assistance please let me know.
Posted on Aug 12, 2008
  • broyles2 Jan 07, 2011
    You can even take the valve out and disassemble it to clean it out. If you use cold more than hot, you can switch the insides so the good valve side is on cold. The whole assembly is easy to replace and inexpensive.
SOURCE:
My top loader washing machine is not getting enough water-trickling only on cold water (hot is ok).
The inlet valve has failed & needs to be replaced unless you don't use hot water then you could just swap the hoses over.
Feb 18, 2011 | Fisher and Paykel IWL12 Top Load Washer
The cold water just trickles out.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Oct 14, 2010 | Roper RAS8445KQ Top Load Washer
The machine will not fill on cold water cycle( only trickles in)
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Sep 16, 2010 | Kenmore 24032\24036 Top Load Washer
The cold water trickles. There is a "good" flow of water (hot&cold) to the machine yet, the cold water trickles out on any cold setting. The hot water has great flow. What could be the answer?
Sounds to me like your inlet valve is gunked up. You will need to replace your inlet valve. I would also check your hoses first to make sure the cold water hose does not have a screen on it that is full of calcium deposits. Hope this helps _MJ_
Aug 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
My Maytag Neptune does not dispense hot water. Just a trickle. Warm and cold are OK
I'm not a repairman, only a "doityourselfer". Try some or all of the following:
1. Check water valve to see if it full open.
2. Check the hot water hose inlet on the back of the machine. Look for a strainer that may be clogged in the hose inlet (turn water valve off first).
3. Check hose for kinking.
4. With the hose disconnected from the washing machine, try running some hot water through the hose into a bucket just to verify the water is available.
5. With machine set to hot water wash, start a cycle and listen for the hot water solenoid to "click" when the machine is started (some solenoids are louder than others so listen carefully). If water begins to trickle in when you here the click then the solenoid is probably working properly.
May 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Cold water will not flow into machine
either the valveis faulty or the dispenser box is blocked, remove the internal hose from the valve anf see if you have full pressure at that point if yes box is blocked. Regards Advisor
Aug 20, 2006 | Hoover Nextra HNT 2135 Top Load Washer
Whirlpool LSR7333 Top Load Washer Logo
116 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
