Question about Soyo Onyx DYLTO32D 32 in. LCD HDTV
Tv 1080 signal not responding to cable to get hd format
  • Anonymous Aug 25, 2008
    i got an new tv its an soyo an i cant get the iptv to work on it they say i need an code for the iptv an i cant find one can you help please
I have iptv an we cant get this tv set up on it can you help me please
Posted on Aug 25, 2008
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
720 and 1080 resolution
depend if your TV dos 720 & 1080 ill look into this more for ill get back 2 u soon
Aug 16, 2008 | Toshiba 42HP95 Television
How do we covert our panasonic TH- 42PWD7B to HD?
Replace it if you want true HD. The TV has 640 × 480 pixels (dots) in use for 16:9 or 852 × 480 dots for 4:3. This translates to 480p or SD resolution.
You can watch an HD signal with downconversion. You will also need a digital to analog converter for OTA signals since the TV doesn't have a digital tuner (ATSC in the US) It reads NTSC, PAL, PAL60, SECAM, Modified NTSC signals in the following formats: 525 (480) / 60i · 60p, 625 (575) / 50i · 50p, 750 (720) / 60p · 50p, 1125 (1080) / 60i · 50i · 24p ·25p · 30p · 24sF ···· SMPTE274M, 1250 (1080) / 50i.
I hope this helps.
Jan 11, 2011 | Panasonic Televison & Video
Sanyo 46" 1080.must you use hdmi cable to get best picture?
Yes. HDMI cables are the best for sound and picture quality with an hd signal at this time than anything else. A lot of people can't see much of a difference using HDMI rather than s-video, component / video, or rf cables but there is a slight difference. You will have to have an hd signal or source such as an hd sattelite receiver, an hd cable box, bluray, etc to benefit fully w/ an hdmi cable.
Aug 03, 2010 | Sanyo Televison & Video
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Just fixed the convergence chip problem.$534.00. Now 720p and 1080 1 signals are showing double images and colors. Also the componentinput #2 is showing double images on any format
many of these sets need the convergence adjusted in the 480 and the 1080 separate-- the set most likely if looks good in 480 needs to be adjusted with the original remote in the 1080 mode.
Whoever charged you 534 got you---if you did it yourself you paid way too much--with 1080 signal--enter convergence mode and try to adjust in customer menu--if 480 is ok---it needs to be adjusted in the hd mode.
SD TECH
Oct 31, 2009 | Pioneer SD-643HD5 64" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
TV PICTURE ISSUE
sir thers no problem with your unit its the user's fault
Jun 26, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Phillips hdtv
if the cable box is sending in 1080 signal the tv will not be able to format to a 480 (you can switch to either/or)
the problem you have is if your not sending 1080 to the tv your not really watching HD but you cant strech the 4:3 (non HD channels) to the 16:9
the only thing you can do is run analog signal and a digital signal then switch between the two sorces for your HD and non HD programs
Mar 11, 2008 | Philips 42PFL5332D 42 in. LCD Television
Soyo Onyx DYLTO32D 32 in. LCD HDTV Logo
150 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
