Pioneer VSX-D509S Receiver Logo
Posted on May 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Poweroff and shut down - Pioneer VSX-D509S Receiver
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on May 05, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2764924
Points
24828
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
After turning on my reciever i get a flashing poweroff on the display. unit then shuts down
check your speaker connection. if that doesn't work check your fuse to make sure it's good.
Sony cybershot dsc-w120 lens goes crazy whenever I turn it on and tells me to turn it off.
The camera should go off automatically when faulty. attempt to explore teh functions on the camera is discover the unique experience beyond power shut down requests. When powered on, capture a snap shot immediately or else the camera takes charge to poweroff to save batteries. Also, attempt to power charge since the insufficeient battery does not allow the camera to stay on long.
2helpful
Protron tv 3250 tv went off. only blue light blinks
Your TV has two poweroff functionalities. First power off button is on saver mode least displaying any transmitter programs. Using the remote control to power off the device achieves screen saver poweroff mode. Second manually pressing on the power button after power saver mode has been achieved with the remote control device should shut down the TV tube entirely. The blue light should not display in whihc instance. Howerever, a full power off mode is incapable of being controlled by the remote control device whenver poweron is required later. The TV power shut down button has to be pressed again to alow for current circulation once more. Powering off the TV with the button on the set requiries momentary duration waits whenever to achieve display of signals depending on the size of the TV, and how many pheriperal device connnections are attahced to it.
refer to the TV user manual for possible diagnostic to any persistant conditions.
Good luck
2helpful
When I turn my optimus STAV-3770 on it reads poweroff and then cuts itself off..please help me
unfortunately most stereo mfgs. install a protect (shutdown) citcuit if it detects an internal short (bad amplifier )or a external short( bad speaker)....disconnectl speakers see if it still shuts down if so there is a genuine component failure inside..however if it stays on then in all likliehood its a bad speaker
VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
3helpful
Shuts down after 30 seconds
Maybe the audio amplifier IC are burned
POWER OFF/ SHUTDOWN
Hi,,,thanks for your good response...Understnding a 7.i surround system through chat is difficult...that ws why i couldnt get it right...if i was there at your place i would have solve that it in seconds...anyway you got it done by yourself thats what we wanted...thanks again
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
2answers
Auto power off problem
you have either got the power and reset connectors the wrong way round fro the front panel, or you have not enabled ACPI in the advanced cmos settings to allow the board to support shutdown by Windows. Also check in the power options in control panel and ensure that when you click turn off the pc is instructed to power down.
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
