Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Stuck in incline position
Is stuck in incline position.
Cannot get it to stand up straight
  • 372 Answers
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Posted on Aug 17, 2008
6ya staff
SOURCE:
My Dyson DC65 is stuck in upright position and won't recline to vacuum. What can I do to fix it
The stand assembly needs to be carefully and thoroughly inspected to determine where it is binding or hanging up somewhere.
Jan 15, 2017 | Dyson Vacuums
Dysondc07 will not move from the standing position
The most likely cause is something is stuck in the valve that switches the airflow from the floor to the tools as you pull the handle back.
Sep 30, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson 18 wont stand
check this video out
Dec 03, 2012 | Vacuums
The bar is stuck so I can't get it to stand upright again?
please go to web page from Dyson:God bless you
use with common sense.look for your model and proceed
http://www.dyson.com/support/help.asp?article=1451&product=DC15-SY-HSN
Jul 27, 2012 | Vacuums
I'm trying to get my S7000 Miele to stand upright an lock in this position. It wont , i tried to see if foot release was jammed but cant tell it doesnt seem to release to let it move upright an lock in...
There is a rear dust cover that sometimes gets stuck, this will make it almost impossible to lock the handle up. First locate the cover which is at the rear right above the wheels. It's about 2"x8" and ribbed vertically and slides up behind the rear panel of the lower body. If it's in there and stuck, just realign it with the 2 grooves on each side or remove it completely; it is a dust shield after all. The best fix is to replace the rear panel and dust shield and they are ordered together and the cost is fairly low. Also check the alignment of the rear body panel at the bottom There are 2 tabs that protrude down about and inch on each side, the one closest to the handle release lever sometimes gets bent and causes the unit to jam. If this does not help there is one more solution involving the rear wheel assembly. check to see that the rear wheel axel is straight, meaning both wheels are parallel at all times while releasing the handle. If the axel is crooked, the wheel assembly must be replaced and you should have a Miele service center order the part and do it for you.
May 01, 2011 | Miele S7210 Bagged Upright Vacuum
The vacuun don 't turn off
Please unplug the unit.
2. Check to make sure the button is not stuck in the on position. 3. If the switch is stuck, try to move the button in the off and on position 4. If the problem persists, you may have a defective button stuck in the on position 5. Please do not attempt to disassemble the unit as the risk of electricution is high.
Jan 08, 2011 | Kenmore 25512/ 25513 Progressive Canister...
The vacuum won't stand back up. it's stuck down.
looking at the front off the machine... ON the left hand side there's a black button... Push in in the slide the plastic behind it towards you... it should clip into position and the vacuum should stand up again,
Oct 03, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The back wheel carriage is stuck in the lowered, vacuuming position...will not go back into place for the unit to stand upright
Hi its Darran at Dyson.
So we can help you resolve this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Apr 12, 2010 | Dyson DC25 All Floors Bagless Upright...
Beater bar not turning, making loud sound
This machine has a clutch assy. that slips and makes a loud noise
when something gets stuck in the roller brush. If you have nothing stuck in the roller brush chances are the clutch is worn and needs
replacing. Not an easy job and best done by a repair tech. You can find a video on youtube showing how to replace the clutch if you are
inclined to try to do it yourself.
Tom
Oct 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can't stand upright
Hi.
If you go to the Dyson web site in there help section it shows how to sort out this problem its very easy to do.
Jun 01, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
275 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Gerry Harvey
Gerry Harvey
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
