Technics su g70 amp problem also?
Help!
I was getting limited sound from my stereo after disconnecting and moving across the room. Now I am not sure if its the amp or speakers. I never blasted the volume out of the speakers while trouble shooting/reconnecting, but I did hear the amplifier fan whirring very loudly when I was rehooking it up and testing the components. The speaker wires when jiggled in the back might allow for some sound, but not when I 'clipped' them into place. Did I blow out my amp?
Have this amp,sound was cutting out on one channel.One day no sound,it turned out to be the solder joints.If i grabbed the rear speaker connectors and twisted they worked again.Take it apart an check the connections and resolder those.
Posted on Oct 07, 2008
    Scholar:
  • 106 Answers
It doesn't sound like it. but maybe. it would be the input section of your amp that blew if it did go. try replacing your speaker wire first, if that doesn't work then your volume knob(if the volume is analogue) may need to be replaced. if that doesn't work. then you may have blown the amp. what source are you testing with?(cdplayer, dvd player, etc.) and what inputs are you using? (analogue, digital optical, digital coax)
Posted on Aug 23, 2008
No sound from stereo
Greetings
the power module is damaged and the components ... as you described, resistors burned and other components are over heated .
you need a service technician if you are still hanging on your baby :)
unless you are a technician .i will be glad to send you send you schematic.
i cannot post it as(PDF).
Dec 29, 2013 | Technics SU-G75 Amplifier
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
About amplifier specification
sounds like you need a service or users manual...check their website,to find one
May 25, 2008 | Computers & Internet
Over heating
make sure there is nothing within several inches of it to start off. if need be, use a small house fan pointed at the amp to help cool it, if all else fails and/or you don't want to hear the noise from the big fan; get a computer fan the same size as the one in the case. connect it in place of the fan that does not work(may have to cut/splice the wires). that should work. oh, check the voltage and whether the fan is AC or DC from the stereo. this makes a huge difference!!!! if the fan says "DC" DO NOT CONNECT AN AC FAN TO IT!!! the fan will short and BLOW UP!!!
May 19, 2008 | Audio Players & Recorders
Technics su-v98. Powers on but no sound can be heard, not even through the headphones jack.
Make sure it is not on mute. Check rear of receiver to make sure AUDIO IN has not become disconnected. Check input selector and verify that it matches the audio source.
Apr 03, 2008 | Audio Players & Recorders
Technics SU-G70 clicks but doesn't display or sound
I just got mine back from repair shop, same symtoms, they replaced power supply, in your case it was hit and miss for a while, so maybe bad power supply connections inside.
Jan 04, 2008 | Audio Players & Recorders
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
480 people viewed this question
 Grubhead
Grubhead
