Question about Acer TravelMate 8204WLMi Notebook
Extremely loud fan
I suspect that my cooling fan has failed. When I use the graphics card, or CPU intensively, i.e. gaming, video editing, 3d modeling and rendering, the area where the cooling fan and exhaust vent are located becomes extremely hot, and as the fan speed climbs in an attempt to compensate, it makes an increasingly loud and obnoxious buzzing. Airflow through the exhaust port is also greatly diminished compared to before this problem began. I understand that the likely solution is replacing the fan, but I cannot seem to locate any information about the part, relevant part numbers, or exploded view diagrams. I was wondering if you could either refer me to an Acer parts dealer, tell me where I could find an exploded view, or possibly how I could fix the fan.
The laptop is out of warranty, and I am entirely unwilling to pay $225+shipping to have someone else replace a part that should cost practically nothing.
  • Jonah_0c Aug 13, 2008
    acerspareparts.com didn't happen to have a replacement cooling module.
    I am aware of the dusty fan blade problem, it was the first thing I checked; a cooling pad was not merely an option, but rather a necessity, as the laptop would overheat in its absence. Rather than buying a cooling pad, I gutted an old power supply and put an 80mm in it; the laptop functions better than ever, kept cool to the point that the internal fan rarely even comes on.
    The issue is portability; I may or may not be near a power outlet in class, so a cooling pad isn't an option, nor is a noisy internal fan.
    In addition to loud, the fan fails to produce airflow remotely significant to the flow when I bought the laptop, and this failure causes overheating. Perhaps I'll have to spend the time on the phone with Acer.
    Thanks for your time!
2 Suggested Answers
SOURCE: Extremely loud fan at high fan speeds
dont know if this is still a problm but just fixed mine. There is a gap between the fan housing and the heatsink, that has tape wrapped around it. When I removed the whole fan and heatsink assembly, unwrapped the tape, there was a plug of dust in this gap. Just pulled it out, wiped everything with a brush and reassembled. Now perfect!
Posted on Apr 09, 2009
My ati radeon graphics card cuts out after about 20 minutes of intensive graphic gameplay use. this is not 'hard' graphics such as wow but just with use on facebook games and yet it will run all day w
Do you have a system utility that will let you check the temperature of your graphics card and your CPU? If you do, check if the temperature is rising significantly while you play. (For a 32-bit Windows OS, a free option is SIW (Software information for Windows available here: www.gtopala.com/ )
The next question is which model card do you have? Does it have a fan? Check if your fan is running properly. (For some computer cases, you can add a slot cooling fan next to the video card or an extra side fan to bring down the temperature enough to play Facebook games.)
Next check that your power supply is not getting overloaded. Some power supplies are labeled with their maximum peak output wattage. So if your video card demands extra power when doing intensive gaming, the power supply may not keep up.
If there is a fan on the ATI card that is not spinning, then you probably should replace it. It's possible to remove the fan from the card and then peel off the seal. Then add a drop of a machine oil that has few contaminants. (I use sewing machine oil or fishing reel oil.) Then replace the thermal compound and reattch the fan to the card. However, I tend not to trust this fix to last. There are replacement VGA card fans but finding one to fit your card can be hard.
I hope this helps.
Nov 13, 2011 | Computers & Internet
Whenever I play games such as APB: Reloaded or anything that I suspect uses 3D settings my computer locks up and has sound loops. From there I cannot regain control of my computer (alt+tab, alt+F4,...
I suspect you have an overheating issue which is causing the lock ups. try running the pc with the side cover removed. If its performs ok then overheating is your problem. You may require extra case fans. it is also possible that your cpu fan and heatsink are clogged with dust. also check the fan on the graphics card for dust. Do not use an airduster, use a hoover with the power to the pc disconnected. Try not to let the hoover touch the components only the fans and heatsinks.
Good luck
Jul 31, 2011 | MSI GeForce GT 430 - 1 GB GDDR3 -...
Acer Aspire 9815WKHi Graphics Card was getting very hot, also the processor gets extremely hot, the fan is working, but cannot keep this computer cool and this has caused the graphics board to stop...
No it is not normal for the graphics to fail unless the heatsink and fan are so badly clogged.
The cpu will stand temperatures of up to 90 degrees but, it gets the main body of the cooling and the graphics chip does not get as well cooled, what happens is the graphics chip then suffers and the solder "bed" it is fixed by melts and the chip detaches.
You may be lucky and by cleaning out the cooling components get it working, but I suspect the motherboard has been damaged now
Jan 14, 2011 | Acer Aspire 9810-6829 Notebook
Does sony vaio need GPU cooling
No if your surfing, e-mailing, or word processing. Maybe if your gaming, video editing, or intense graphic designing.
Oct 30, 2009 | Sony CPU FAN CPU Fan
Want to buy a new computer for personel use , which cpu is better dual core or core2duo girish email. girishpratap@yahoo.co.in
If you going to be using intensive programs like 3d editing, gaming, video editing, photoshop/image editing, or just multitasking and keeping alot of programs open you should get a faster cpu speed, and probably the core 2 duo. Core 2 duo (intel) is dual core and 64bit which gives more processing power, for some applications. Dual core is just normal processor (32bit) and just has 2 cores.
CPU is basically for the computers thinking/multitasking/processing info. If you want to multitask alot of programs your going to need processing power AND alot of RAM, the more the better/faster. If your going to be gaming or doing intesive stuff with graphics, you need a powerful video card. And hard disk is solely dependent on your storage needs too.
If your just going to be surfing the web, emailing, facebook, watching dvd's, and whatnot, any computer (new) should do you fine. But if you want HD video you need a powerful video card and processor.
Also When I mean powerful I dont mean the most powerful, just the mid-range of 'power'. So if you want to get anything more than basic, go for a mid-priced PC. Also this will let your computer last longer as updates and new software tend to slow down your computer, and you need more power to keep up with new stuff, but don't worry, it wont happen that fast!
Feb 27, 2009 | Intel Core T2300, 1.66 GHz Core Duo...
Visiontek hd 2400 pro game graphic lag
most computers systems have certain drivers configuration setups for certain games so you dont have that problem.
control panel, open up personazation,open display setting, find advance setting, open the folder that matches the type of graphics card you are using.
open the control center
3d settings
game setting
display options
avivo tm video
power players
graphics: hardware & software options
rod
Feb 26, 2009 | VisionTek ATI RADEON HD2400 Pro Edition...
My games keep telling me {unable to create 3d device} when ever i try to acess my games e.g jamesbond nightfire
I CAN HELP YOU WITH THIS PROBLEM IT IS IN THE ADVANCE SETTINGS OF THE VIDEO CARD SYSTEM DRIVERS
GOTO CONTROL PANEL AND OPEN UP FOLDER CALLED DISPLAY SETTINGS
FIND BOX SAYS ADVANCE SETTINGS
OPEN THIS FOLDER INSIDE THE FOLDER YOU ARE GOING TO SEE ALOT OF OTHER FOLDER AND THEY MAY ALL HAVE THE SAME INFORMATION MINE SAYS:
ADAPTER,
COLOR MANAGEMENT,
MONITOR,
TROUBLESHOOTING,
GAMING,
ATI CATALSTIC [TM] CONTROL CENTER ( OPEN THIS FOLDER)
INSIDE THE FOLDER IT ASK YOU AGAIN IF YOU WANT TO OPEN IT AGAIN AND YOU WANT TOO CLICK ON IT
INSIDE THIS BOX YOU ARE GOING TO HAVE THE FOLLOWING INFORMATIONS:
GRAPHICS SOFTWARE & HARDWARE
DISPLAY MANAGER
DISPLAY OPTIONS
MONITOR PROPERTIES 0 OR 1
3D SETTINGS
COLOR SETTINGS
AVIVO TM VIDEO
POWER PLAY
SOME OF THESE HAVE WHERE THE COMPUTER WILL SETUP CURTAIN DRIVER FOR THE GAMES YOU WANT TO PLAY, HELP FPS, GRAPHIC INTENSE, FAST SPEED, CONTROL SPEED OF FANS, CPU, COOLER DEVICES AND SO ON.
YOU WILL HAVE OPTION TO PUT THE ICON ON THE START UP MENU EVERYTIME THE SYSTEM STARTS UP SO YOU CAN MAKE CHANGES ON THE FLY.
OTHER OPTIONS: VIEW,HOTKEYS,PROFILES,PERFERANCES,AND HELP, AND SYSTEM INFORMATION
2D OPTIONS
2D DRIVERS FILE PATH & DRIVER VERSION
DIRECT3D
OPENGL VERSIONS
PROVIDERS
DRIVERS PACKAGING DRIVERS
GAMING OPTIONS
EVERRY GAME BOX YOU PUT A CHECK MARK IN WHEN YOU ACTIVATE THAT PROGRAM IT WILL LOAD YOUR DRIVERS FOR THAT GAME AND WHEN YOU SIGN OUT THAN THE COMPUTER WILL WANT TO RESET TO ORGINAL WINDOWS SETTINGS
REBOOT
ROD
Feb 21, 2009 | Dell GeForce2 MX, (32 MB) Graphic Card
Shutdown after graphic intensive use
It would seem in my opinion from the information you gave, that your processor of graphics processor is overheating and shutting down the laptop. Possible the cooling fan is not operating correctly. Do you hear your cooling fan running at all?
Hope that helps.
Dec 17, 2008 | Global Marketing Partners Smart Restart By...
If you remove the hard drive bay and memory bay underneath the laptop, you should be able to see the fan attached to the motherboard, if not completely remove the bottom section of the notebook, you may find that there is a build up of dust on the phone, hoover this off gently, you may find a big difference as dust causes fan imbalance
Aug 10, 2008 | Acer TravelMate 8204WLMi Notebook
Acer TravelMate 8204WLMi Notebook Logo
267 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
