Question about Maytag Washing Machines
Seal leaking from tub. How do I remove agitator?
  • 5,911 Answers
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
Posted on Aug 12, 2008
Kenmore 90 series mod 110. 478621 leaking from above the transmission . How to check drum seal. Thanks
Remove the agitator, you need a spanner wrench to remove the nut holding the spin tub down, then it will lift out. You will need a new tub donut seal that fits into the outer washtub, check for corrosion on the support tube, if it is corroded and not smooth, it will likely leak with the new seal.
Apr 23, 2016 | Kenmore Washing Machines
Elite model #11027087603. How do I remove tubseal nut on bottom of washer that holds motor rotor on shaft?
that should have an inset, hex-headed screw/bolt. You will have to hold the rotor with one hand and use your other hand to loosen that screw. they use thread lock on that screw, so it will be difficult. but, that's only half the battle. You will have to remove the tub cover, agitator (7/16 agitator nut size), and the spin basket to access the tub seal. the seal has to go on from the inside of the tub assembly. Make sure you don't use anything against the outer lip of where the seal seats inside the tub, or you will have to replace the outer tub because it will still leak. Push the seal all the way down. then before you put everything back together, pour a small amount of water in the tub and see if you see any leaks. anything major will show then, but if there is a small leak, you will not know it till you try to wash with it. You shouldn't have to remove the stator screw or do anything from the bottom side of this unit. You should be able to replace that seal from the top side. good luck.
Nov 28, 2015 | Kenmore Washing Machines
How do I remove the hub below the agitator on a top loading Kenmore 110.42722200?
You must remove the 7/16s bolt from top of agitator then remove agitator then pull tub out and the seal is in the outer tub.
Jul 19, 2015 | Kenmore Washing Machines
My Maytag A9700 is leaking from the bottom of the outer tub. I have changed both the tub bearing and the stem seal but it is still leaking - even more than before I started. My question is whether I
If the boot seal was properly seated onto the outer tub lip, then you should focus on the water seal (#39 in the graphic - it should have come with the mounting stem kit) as the source of the leak. Extra care must be used when installing this over the agitator drive shaft - some recommend adding a lubricant (Maytag center seal grease works well) to the shaft before sliding the mounting stem (and water seal) down onto the agitator shaft. Also, check the two sealing surfaces where the top of the boot seal (#40) meets the bottom of the mounting stem (#30). Look for cracks, chips or any bits of debris. Anything that keeps those two surfaces from meeting perfectly will cause a leak. These repairs should go fairly smoothly, but leaking water seals and chipped boot seals can cause problems.
Dec 06, 2014 | Maytag Washing Machines
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
When the washer goes unto spin cycle, it makes a loud roaring noise and is leaking from the bottom
It sounds like the tub seal is leaking, allowing water to leak out of the tub and damage the drum bearing. Unfortunately you need specialized tools to replace the seal and bearing, so you may have to get a maytag service agent in to look at it. If you're handy with a welder you may be able to make up a tool yourself, it basically consists of a flat hexagon with tabs on the inside to fit the drum nut, and some handles on it. You'll need to remove the front panel and top panel. Then remove the cap around the top of the tub. The agitator is held on by a small screw near the base of the agitator, loosening it will allow you to remove it. Now you can see the tub nut, this is reverse threaded, so it's loosened clockwise. Then you can lift out the drum. Next on the shaft is the top part of the mechanical seal. Remove the grub screw out the side. Now you'll need the same tool you used for the tub nut to undo the seal, rotating in the same direction. Remove the outer tub by undoing the 3 bolts that fix it to the stays, and disconnect the level tube and drain hose. From here you should have printed instructions that come with the new parts to replace the seal and bearing. Please feel free to get back to me if you have any further questions.
Jul 28, 2011 | Maytag Washing Machines
How do we remove the tub seal assembly on a mat12cs commercial Maytag?
This is a not a job for the back yard mechanic. There are many things that need to be done carefully. There are 3 letters missing from your model number also... However the procedure is pretty much the same for all models.
NOTE you will need a special tool to remove the stem seal. Unless you have the special tool in hand don't even bother starting the job. Tell any appliance part center you need the tool for removing an Old style Maytag tub nut and stem seal.
1. Remove the front panel
2. Remove the cabinet top / lid by removing the 2 screws in the top front corner of the cabinet. and rotate the top up 90 deg. Be careful of the lid that will swing freely.
3. Disconnect the pump inlet hose from the bottom of the tub.
4. Disconnect the water injector hose from the tub cover.
5. Remove the tub cover
6. Locate the only hex head screw in the side of the agitator and remove it.
7. Lift out the agitator
8. Using the special tool you should have in hand by now.... Remove the wash tub nut and stainless steel washer under the tub nut.
9. NOTE the distance of the inner tub from the outer tub and then lift out the wash tub
10. Next is the stem seal. You first have to remove the allen head lock screw in one of the 4 faces of the tub nut. Then again using that same special tool remove the upper part of stem seal. Be careful when lifting it as you can actually damage the grease seal in the very top of the tub seal upper portion. Once the metal upper part of the tub stem seal assy is removed... there another NOTE of caution...
11. The actual tub seal has a carbon face on the top of it and if you crack the carbon seal it your machine will leak all of the time there is water in the unit.
grab the tub seal as the very base of the seal and gently rotate and lift it off the inner tub sealing surface.
12. Install the new stem seal.... by again gripping it on the bottom only and gently rotate and push it down into place until it seats level.
Reassemble in reverse order of disassembly but make sure you INSTALL the allen lock screw into the stem seal nut face. If you don't the stem seal will come loose and your unit will leak again. Final note is during re-assembly make sure the wash tub is centered.... rotate the tub once you tighten the tub nut and make sure it is not to elliptical if you don't get it right... the machine will gyrate with use in the spin cycle.
Jan 14, 2010 | Maytag MAT12CS Top Load Washer
Water leaking where motor goes into the drum
there is a tub seal under the spin tub that proab needs replacing open the front panel then raise the top then grab the agitator and **** up on it hard it should snap out then unsnap the splash ring around the outer tub take the little bolt out of the agitator drive loosen the nut on the spin tub and remove it keep going down till you get to the tub seal replace it then reassemble
May 22, 2008 | GE WHRE5260E Top Load Washer
HELP!! Leaks!! Leaks!!!
the inner tub and outer tub has a seal under the agitator. this must be replaced. use a spanner or a large channel lock plier to remove the nut. seal is underneath it.
Sep 04, 2007 | Frigidaire GLWS1233A Top Load Washer
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Open Questions:
Washing Machines Logo
219 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
