Question about Video Cameras
Sony dcr-trv17 when tape inserted "C:31.23" flashes
  • 1 more comment
  • jwajr12 Jan 18, 2009
    I have the same problem. Mine has been intermittent, but gotten more frequent lately. Get a complete blue screen with that code flashing... Have one $371.00 estimate to repair, but I can buy a new hard drive camcorder for that... Help!
  • twwr Mar 08, 2009
    I had an error of c:31:22. emailed Sony and they said it was a power problem and would have to be serviced......with $200.00 plus parts to repair (also handling and shipping)
  • findbrad3 Apr 17, 2009
    same message C:31:23 with the blue screen...any news on this?
I have the same issue and found that on most forums that the only way to fix it is to try smacking the side of the camera relatively hard with the palm of your hand. BUT, I discover the issue, the issue here that the cam did not recognize when the tape starts at the begining, So the cam try to keep rewind the tape to reach the begining while in the real the tape is in the begining and this cause such error, How I avoid that, Just you need to forward the tape (MANUALLY) from its begining couples of turns (rounds) and then turn the cam, suprize it is working....lol.
my conclusion is if you use the tape couple of times then you need to replace it...Mohanad.
Posted on Feb 28, 2009
Go to youtube tutorial on this at http://www.youtube.com/watch?v=VUIN-ygjN_g. Look at it carefully before smacking your camera. I did it and my trv25 works perfectly
Posted on Jun 16, 2009
Drawsalot
  • 38 Answers
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Posted on Nov 21, 2007
  • 169 Answers
SOURCE: Sony DCR-TRV140 CODE
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser..
Posted on Apr 13, 2008
SOURCE: C:31:23 Flashing and viewfinder says "Reinsert the casette"
i know what setmaz says sounds kind of ridiculous; but i got desperate and tried it myself... i can say that as far as i go its a proven method and the camera will start working
Posted on May 14, 2009
SOURCE: Sony DCR-HC38 error C:31:22 re-insert tape.
Sony is a ******* piece of **** corporation that has foisted their name on professionals and consumers as being the epitome of high technology for all forms of media.  They are, in fact, scam artists that have perfected the art of programmed obsolescence and early life failures for their equipment.  Because I have been a professional video/audio engineer for 30 years, I have been forced to own and use more Sony gear than I am comfortable admitting to.  There is NO answer to your dilemma because it is a defect programmed into the circuitry of Sony DV-Cams that will ultimately force you to take the machine in for repairs...again and again and again and again....
Do your self a huge favor and smash that piece of **** with a sledge hammer right now.  Then, go out and buy a Canon.  Great products and great tech support.  Sorry I couldn't solve your problem for you.  But, I am an engineer and I can't even solve this one myself.
Posted on Sep 08, 2009
  • 85 Answers
SOURCE: My Sony Handycam DCR-HC26 started giving me
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Posted on Mar 20, 2010
Sony DCR-TRV17 - In the middle of filming, a flashing yellow square with a yellow light bulb inside the square appears wiht chimes. upper right hand corner is flashing C:21:00. I turned off recorder and...
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
May 31, 2010 | Sony Handycam DCR-TRV17 Mini DV Digital...
I can't record because of an C:31:23. Can I fix
nope i dnt think ,u wuld nt be having proper jig and tools to repair it as , this problem is related to the mechanical section . ... and occurs due to the tension of new tape .. try using old tape .......
Jul 16, 2009 | Sony Handycam DCR-TRV17 Mini DV Digital...
SONY DCR TRV350 C31:23 and C31:22 flashing code
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jun 15, 2009 | Sony Handycam DCR-TRV240E Digital...
Sony dcr-trv480 video camcorder error
I also have this problem, with a SONY DCR-TRV480E PAL. The problem is when I insert the cassette it reads on screen that "re-insert the cassette"
May 04, 2008 | Sony DCR-TRV-428E Hi8 Easy Handycam Pal...
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Tape compartment won't open
eject the tape by disconnecting the power adaptor and removing the battery. After waiting a short time and then replacing the battery, the tape would eject.
Dec 07, 2007 | Sony Handycam DCR-TRV17 Mini DV Digital...
Camera will not accept mini-dv tape anymore
Hello dear sir;
I have SONY handy cam(model 42E) that finger touch keys doesn’t work .what do I do now.
Please help me and send a procedure to repairing.
I am Iranian mechanical engineer.
Oct 24, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Video Cameras Logo
1,377 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
