Question about HP PSC 2410 All-In-One InkJet Printer
On light won't stop blinking and on the display there is an hour glass
When we turn on our printer it keeps making a clicking sound and when the sound stops the on light keeps blinking and the display has an hour glass that won't go away.
  • Anonymous May 24, 2009
    I tried but this solution does not work. I am ready to throw the printer away. The printer is in its own "world", turning off, unplugging, reinstalling software, resetting to default setup, nothing seems to work. I wish there is a reset button so I can literally start from the beginning. I experienced this problem several times. After days of trying different things, somehow the hourglass would go away. But I never figure out what I did which is frustrating. That means I don't know what to do next time when I encounter the same problem.
    I searched the Net for a solution and realized this is a common problem. I had bought many HP printers throughout the years. I think this is my last HP printer. Too bad.
  • 446 Answers
There is a pending job queued, unless this file has been released and printed you cannot removed the light from blinking. pls cancell all doc spooled on your pc and select cancell all, press the cancel button on your printer as well then turn off and on your printer
Posted on Aug 11, 2008
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
That scanner light comes on when I turn on the printer, but it fails to stop at home. Like it is out of time or something. It just keeps clicking the drive motor for the scanner. Have to shut it off to...
For tech guys only: Remove ADF unit, remove control panel bezel, remove flat bed screws & take out flat bed cover(glass), detach CCD cable & belt take out CCD unit, Remove bonnet of CCD you can observe three reflecting glasses fixed in it, clean gently these glasses with ear buds or any smooth cotton carefully.. fix it back, clean flatbed glass in side.. fix unit back & try.. 80% cases resolves with this activity if not resolved replaced CCD unit...
Jul 18, 2012 | HP LaserJet 2840 Printer
My Dell 1320c printer toner light won't stop blinking
this will sound dumb, make sure you remove all the shipping materials from the cartridge including anything that may be over the electronic components to let the printer identify the new cartridge.
Apr 03, 2012 | Dell 1320c Laser Printer
Epson Stylus NX105 scanner started clicking when turned on...
I dismantled the printer because i've been having the same issue. It recedes to the right and begins clicking because it is at the end of the track. For some reason the scanner isn't registering that it is at the end of the track and keeps persisting making the gears jam up on the other end because they obviously can't move any further. Any suggestions as to how to fix, or master reset?
Aug 28, 2009 | Epson Stylus NX105 All-In-One Printer
I have a hp 2410 and get only blinking green light and hour glass. Cant print or scan even fax.. I tried re installing the printer.. but still the same problem exist..It also makes a grinding sound once...
unplug the power cord from back of printer and than press and hold the ON button for 30 second, than release the button than connect the power cord and turn on the printer
Aug 09, 2009 | HP PSC 2410 All-In-One InkJet Printer
DOES NOT TURN ON BUT LIGHT BLINKS AND MAKES FUNNY NOISE
I am having the same problem. BLinking green light and hour glass only. hp 2410
Jul 03, 2009 | Panasonic KX-FLB801 All-In-One Laser...
Hp 2410 just clicking
When you power on the printer.
See if the scanner light move to the right and then keep on clicking.
If this happen, the scanner head is unable to find home position.
You will have to clean the strip under the glass.
If this only start to happen recently, you could unplug the printer and wait 1 hour.
Replug in the printer will at times stop the clicking.
You can go to http://h10025.www1.hp.com
Enter c00553775 into the search block.
Click on Hp All in one how to clean scanner glass.
This will bring you to the HP document.
Jan 27, 2009 | HP PSC 2410 All-In-One InkJet Printer
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
On off light keeps blinking
try the following:
1. restart the printer spool service in by going into the services applet in the administrative tools section of control pannel
2. check if there's an updated driver for your printer:
uninstall the old driver and printer, reinstall the new driver and printer then test
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&rule=8638&product=303753&
(copy the entire link in the browser address box and hit enter)
post your findings!
Dec 01, 2008 | HP Photosmart 2410 All-In-One InkJet...
2410 printer will not print
 This is Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue related to the lights blinking and Clicking sound on your Printer. I would like to provide my suggestions on the issue.
This is an issue related to the Printer Carriage stall on your Printer. To resolve the issue, Please try below solutions.
Solution 1:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00299915&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Please open the above link and perform the steps mentioned in the web page.
Oct 22, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
403 people viewed this question
Seeker5211
Seeker5211
