Question about Konica Minolta magicolor 2490MF Laser Printer
NAND FLASH ROM ERROR - 2490MF
I have a 2490MF and before giving the error below, it had indicated that the Y, M and C toners needed to be changed.
Error : NAND Flash ROM ERROR
IA CODE CHECK SUM
I'd appreciate any assistance as i am stumped
  • 1 more comment
  • paulelliott Nov 21, 2008
    as above I have the error NAND FLASH ROM ERROR
  • Anonymous Jan 28, 2009
    I have the same error
  • heliumsucker Apr 15, 2009
    Phaser 6115 MFPError :
    IA CODE CHECK SUM
    Sniper:
  • 62 Answers
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Posted on Aug 13, 2008
Nand flash rom error
I'm afraid it is the switch that is giving the Nand memory error, but can't verify this, because I don't know what model you are using. I can't find an error like this in the Epson high performance printer.
Do you know what switch you are using? Cisco has thousands.
Oct 29, 2013 | Office Equipment & Supplies
Konica Minolta 2490mf . Have just put in compatible toner catrdges and printer is telling me YMCK toner incorrect can you help many thanks Steve
Perhaps clean the connections between the toner-chips and the printer.
As the are lokated below the toner cartridges in your printer the tend to get dirty
and cleaning them can make the difference...
If this does not help, try the old cartridges and see what message you get.
If that is a different one your cartridges doesn't match your printer and you should get replace ones.
Greetz, Robert.
Sep 06, 2011 | Konica Minolta magicolor 2490MF Laser...
NAND FLASH ROM ERROR IA CODE CHECK SUM
you need to update the firmware here is the link http://www.fixya.com/ftp://ftp.minolta-qms.com/pub/drivers/other/MC2490MF/
install the printer and SCANNER driver via usb
Mar 15, 2011 | Konica Minolta magicolor 2490MF Laser...
NAND FLASH ROM ERROR IA CODE CHECK SUM display on my konica bizhub C10..
Have a Konica Minolta Tech come out and re-flash the machine firm ware, can not be done with out access to a secure web site to down load the firmware
Oct 26, 2010 | Konica Office Equipment & Supplies
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
Jan 13, 2009 | Konica Minolta magicolor 2490MF Laser...
Update Firmware on machine to latest level ,you will need the print driver and scanner driver installed
use the USB connection
Here is a link to the ftp site for firmware download
There is apdf that explains how to update the firmware correctly
to get started turn on machine with the menu key held down the display will change to BIOS mode
then send firmware from program downloaded
Nov 21, 2008 | Konica Minolta magicolor 2490MF Laser...
Change k toner error message
If you want to use the toner cartridge after the printer decides that it's empty, you can do it by going into the Machine Settings in the menu, and option 8 (at least on my Magicolor 2590MF) says "Toner empty stop?". Just change that to NO, and you're set to go.
May 27, 2008 | Konica Minolta magicolor 2490MF Laser...
Konica Minolta magicolor  2490MF Laser Printer Logo
1,176 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
