Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Strange problem about WBR 1310
This router really sucks..
The problem is once I successfully connected to the router, I still cannot access to the internet SOMETIMES, (But very weird that the Windows said I already connected to the local network and INTERNET). But once I restart the cable and router SEVERAL times... then it will worked. But after a few hours... problems appear again...
I already try everything I can do... this problem is exist in both wired and wireless network.
I think this is a bad router, so if you don't know how to fix it, can you tell me any brand and the model of the router that it is stable, fast and wide range. THANKS * a billion
  • Tim Boer Sep 28, 2008
    My router locks up after an hour or so . I have to unplug it the reconnect to restore connectivity to both desktop pc's. ITS REALLY ANNOYING !! I am not sure if weve got bad modems or what?
    Scholar:
  • 93 Answers
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then got to Startup click Disable All and then Apply and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Posted on Aug 13, 2008
Installation problem: D-link wireless router WBR-1310
  1. Push the RESET button on the back.
  2. Plug in the computer only into one of the 4 blue ports (and the router power plug of course).
  3. Give it a minute or two.
  4. Open a browser on your PC, type 192.168.0.1 in the address bar. No www or anything should be there.
  5. You should be able to access the router menu from this address. If this doesn't work, the default address might be listed on the bottom, along with the username and password
  6. If the above steps are successful you should be able to access the internet when you plug in your cable/DSL modem into the WAN port.
From another PC the manual can be downloaded from here:
ftp://ftp.dlink.com/Gateway/wbr1310/Manual/wbr1310_manual_110.zip
Hope this helps.
Jul 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My WBR-1310 doesn't do wireless to my laptop.
theres a couple of version of this router http://www.dlink.com/products/default.aspx?pid=WBR-1310&tab=3 I'm using the manual from here http://www.dlink.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
on a working PC download and install this program http://www.xirrus.com/library/wifitools.php this will detect all the wireless signals being broadcast - see if the router is actually broadcasting - if it is detected on your PC then it may be that 1) the firewall is blocking access or 2) the security code is entered wrong - -log into the router and remove the wireless security and see if you can now detect
Mar 18, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How to secure connection on WBR-1310 d link
To secure the wireless network, you will need to access the router set up.
Is there any computer connected to the router ?
If not then you will need to connect the router to the computer .
Then check the IP address of the computer and open the router set up.
Click Here for step by step solution on how to secure the network
Nov 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dlink WBR 1310 not connecting to a MAC(Apple) network
With power on, push & HOLD reset button on rear of router for at least 10 secs - then release. UNplug power to the cable modem while you're doing all this. Then, plug power to modem back in, and try router connect to computer again.
Please let me know - and if you wouldn't mind, please take the time to rate my response to you.
Thank you and good luck.
gurutim
Mar 22, 2009 | D-Link 802.11g Wireless Router WBR-1310...
WIFI & WBR 1310
Fix your router again. If the wifi is fine, you just have to let the nintendo search for the wireless network and connect to it. You don't have to do anything on the router to let your nintendo to connect.
Feb 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Wii wifi connection
Try to uncheck UPnP Enable on your router located on advaced network setting. or try reconfiguring your wireless network settings.
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
CANNOT CONNECT TO INTERNET
in the installation manual you have a url you can type in...its something like 192.428.111.1...ect about 10-12 numbers...type this number in the internet browser search window. this will tell you first if you have access to the internet. you should get the settings windows for your router. there you can make adjustments as needed for your rounter unit.once confirmed.
if you are having access to the wireless network you set up the password you set in is obviously incorrect when it was set up. first check the light on the front of the wireless router it should have various light on ..such as power,,usb...dsl...and internet..with the internet light flashing... as a precaution please do a repair connection on your internet access point on the computer ur using..right click the wireless icon at the bottom of your screen if ur using xp..sometimes this repair will be just enough to clear up issues.and allow access.
if this continues...you may need to reinstall the unit...there is generally a reset button (very small) on the underside of ur wireless unit and take the appropriate steps..
gl
K.
Dec 30, 2007 | D-Link 802.11g Wireless Router WBR-1310...
Cannot access the WBR-1310 webpage
if you are wireless, after a reset you need to connect with the router using an RJ45 lan connector lead. Reboot your notebook, while connect to router and then type in the default address for the set up page normally 192.168.0.1
Oct 05, 2007 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
595 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
