While there aren't any open recalls I'm aware of for that concern, it may very well fall under the powertrain warranty (5 years, 60,000 miles). The most common rear end noise concern we get is a chattering/noise from the rear end in turns caused by the breakdown of additives in the rear axle fluid causing the limited slip clutches to chatter. The cheapest, easiest fix for that concern is an $8 bottle of "friction modifier", available at the dealerships parts department, that you can add to the rear axle. It will work its way into the friction material, usually quieting the noise after 500 miles or so.
