Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Help I have a SD-533HD5, and I cut on my TV and it instantly cuts off. I saw you mention that it is a fuse. I am not sure what is the best way to take it apart, as I do not want to tear anything up. Any suggestions?
    Scholar:
  • 167 Answers
HELLO ok the first thing to do is unplug the set.!!!!#2 then take off the back of the set.!!! #3 then look for the fuse holder's there will be 3 to 4 of them. and check them to see if there good.!!! # 4 ok if all the fuse's are good .then it still could be a couple of thing's a clod solder joint.!!! or dry socket.!!! or a bad fly back transformer.!!! & horz.out put transtior.!! are bad and need to be replaced. well hope this help's you "GOOD LUCK"
Posted on Aug 20, 2008
I have no power
Since you mentioned that the saw is new, why not try calling the manufacturer. It's the best way to you could do for now.
May 23, 2013 | Hitachi C10FCE2 10" Compound Miter Saw
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tile Saw Troubleshooting
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Vertical lines on screen
this is the convergence gone bad. that is what was blowing the fuse. this is the board on the far left. there are two stk`s on this board. stk392-110.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5 not turn on
Theres 3 boards on the bottom inside of tv. The middle circuit board has 3 small fuses toward the center of the board. Just pop those fuses out and look for the 1 that is broken or burnt. Taken the bad fuse to radio shack and get replacement. Very easy repair.
Sep 24, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red lamp issue
the color which you see has problem i think you might be seeing white slanting lines also with this. it mainly due to 1 supply to green video supply 2 loose cuntact in g.video section 3 green tr. defective 4 ckt from ic to green input is defective 5 chroma ic defective if supply is ok. regards
Sep 14, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
