Question about Car Audio & Video
Flat battery-applied incorrect rdio code numbers found correct code no at home but radio will not accept it. tied disconnecting battery again -no success tried leaving radio turned on for 1 hour as per instruction book - success. removed and replace fuse-no success ? cannot remove incorrect code from display.
  • 1 more comment
  • jdavies740 Aug 12, 2008
    incorrect code will not disapear from screen to enable the correct code to be installed
  • jdavies740 Aug 13, 2008
    Thanks but did that with no success
    also removed radio fuse with no sucess
    Sorry no model number.
    Just an old fashioned radio/tape( yes tape player) in a
    1996 TS Model Mitsubishi Magna V6.
    The Instruction booklet said to leave the ingnition key on 'ACC'
    (accessories) for an hour- did so but no success.
    Could try again for longer than an hour tonight but do not want to
    'flatten' my new battery (installed this morning)
  • 33 Answers
Im sorry im having a little trouble understanding the ?tion, are you trying to remove the radio the correct way or install it and having trouble getting the code off the screen...
Posted on Aug 12, 2008
  • 1 more comment
  • Anonymous Aug 13, 2008
    try unplugging it from your battery and reinstall it...
    ok, one sec let me check something out...
    what raido do you have model number
    ahhh you got one of those old babies... if im not mistaken you can hold i believe its the 1 and 6 button down for a period of time and it will reset it, turn the key over and hold them down... im going to check at work today for that model today... and let you know more if that doesnt work...
SOURCE:
My 1996 honda decker 2000 radio has frozen after 10 incorrect codes used - i now have the right code but it wont accept it
Try disconnecting the battery and leaving it for at least thirty minutes. This should reset the radio back to the zero point. Then enter the correct code.
Sep 27, 2018 | Honda Cars & Trucks
I need a radoi code for my 2002 Mercedes CLK 430
Please check the information that came along with the owner's manual. It should be printed on a card that comes with those booklets. I assume you've already done that though. I've attached the procedure for entering the code below. Let me know if you have any trouble with it.
If the radio is disconnected from the power supply it is not ready for operation when reconnected. After switching on the ignition and the radio the word "CODE" appears on the display and the letter "C" flashes.
NOTE: The five-digit code number for this radio is printed on the CODE CARD which you were given.
Enter the code number with station buttons, e.g. number 1, station button 1.
After entering the first digit the word "CODE" disappears and the digit entered is displayed followed by 4 dashes. The next digit to be entered flashes. After all 5 digits are entered, the first digit flashes again. In this state the code number can be written over repeatedly. A correction can be made only by reentering the entire code number.
Confirming the code number: Press seek-UP/seek-DOWN or SCAN button. The radio switches on automatically and displays the station or frequency stored for station button 1.
If the wrong code number has been entered and confirmed, the word "CODE" appears on the display again. After the code has been entered three times incorrectly the word "WAIT" appears on the display and the radio is disabled for approx. 10 min .
NOTE: The waiting time continues to run only when the radio is switched on.
After expiration of the waiting time the word "CODE" appears on the display again and the correct code number can be entered. After 3 more incorrect entries the radio is again disabled for 10 min . After 3 more incorrect entries (a total of 9 incorrect entries) the waiting time is increased to 60 min . After 3 more incorrect entries the radio locks up again for 60 min .
Certified Auto Service Repair for Audi BMW Greensboro Jaguar Land Rover...
May 04, 2012 | 2002 Mercedes-Benz CLK-Class
I tried to put 3 different codes into my ford focus radio after having recharged the battery and after entering the 3 sets of numbers that i found on the top of the radio it started counting down,,,can...
Good Day Konnie!
Try code 6151
To Enter the Security Keycode for a Ford
1. Switch the ignition ON using the key
2. Switch Radio ON - Display Shows CODE with "-------" flashing
3. Press Preset Button " 1 " repeatedly for 1st Digit of your KeyCode
4. Press Preset Button " 2 " repeatedly for 2nd Digit of your KeyCode
5. Press Preset Button " 3 " repeatedly for 3rd Digit of your Keycode
6. Press Preset Button " 4 " repeatedly for 4th Digit of your Keycode
7. If the display now shows the correct KeyCode number then Press Preset Button " 5 " to Enter
Please do rate my answer.
Thank you for asking Fixya.
Aug 06, 2011 | Ford Car Audio & Video
Changed the battery on our chrysler grand voyager radio locked!
try to unhook the battery again for a minute or two..might help. then try the code again after hooking up battery again.
Mar 07, 2010 | 2004 Chrysler Voyager
I need the mercedes benz 1999 clk 430 radio code
AR82.60-P-7502-01A Coding Radio
(MODEL all with CODE (750) Radio Becker Europa 2000 with CODE (751) Radio Becker Grand Prix 2000 with RDS)
  1. If the radio is disconnected from the power supply, it is not operational when re-connected. After switching on the ignition and the radio, the readout CODE appears in the display.
  2. The code number for the radio is advised to you on the enclosed CODE CARD.
  3. To enter the first digit of the code number, you have to continue pressing station button 1 until the correct digit appears in the display. Adopt the same procedure for the second, third and fourth digits.
  4. Once you have entered the correct code number with the station buttons 1, 2, 3, 4 and confirmed the entry with the SEEK button (press down), the readout CODE disappears. The radio can now be operated.
  5. If you enter a wrong code three times, you must wait 15 minutes before making a new entry. In addition, if 9 incorrect entries are made, the radio will then not operate for 24 hours. During this time the radio and the ignition (terminal 15) must remain switched on.
AR82.60-P-7502-01B Coding Radio
(MODEL all with CODE (353) Audio 30 APS with CODE (510a) Radio MB Exquisit with traffic news decoder, with RDS (Becker) with CODE (512a) Radio MB Special with traffic news decoder, with RDS.)
  1. If the radio is disconnected from the power supply, it cannot be operated by simply reconnecting. After switching on the ignition and the radio the word "CODE" appears in the display on the radio.
  2. The code number for the radio is given on the enclosed CODE CARD.
  3. Enter the code number with the station button, e.g. number 1, station button 1. After entering the first number the word "CODE" disappears and the number entered appears followed by 4 dashes. The next character to be entered flashes. After entering all five numbers, the first character starts flashing again. In this state the code number can be written over as frequently as desired. A correction can be made only by entering the complete code number again.
  4. Confirm code number: Press TUNE, AUTO/SEEK or SC button. The radio automatically switches on and indicates the radio station or frequency stored with station button 1.
  5. If an incorrect code number is entered and confirmed, the word "CODE" appears again on the display. If an incorrect code is entered three times the word "WAIT" appears on the display and the radio locks up for approx. 10 min. If the code is entered incorrectly three times again the radio locks up again for 10 min. Three more incorrect entries (a total of 9 incorrect attempts) increase the lock-up time to 60 min. Another three incorrect entries lock up the radio for another 60 min. The waiting time runs only when the radio is switched on.
Dec 17, 2009 | 1999 Mercedes-Benz E-Class
Ford 6006 cdc cd player wont accept correct code
Either the code is incorrect or you are using the wrong Code Entry Instructions.
To check your code POST ANOTHER QUESTION quoting the  radio`s SERIAL NUMBER  ( can be found on the radio casing or by pressing either buttons 1&6  or 2 & 6 )
It normally begins with M + + + + + + (or V or L or C )
Sep 12, 2009 | Car Audio & Video
98 Accord V6 EX CD/Radio no sound despite correct code accepted
check the wirings of your speakers and then check the settings on your radio.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | 1993 Honda Accord
Acura car stereo lock codes my stereo needs a code is a Acura 3.0CL now it says err-3 can some one help
err-3 means you have entered incorrect anti-theft radio code more that three times.If you do not have radio code you can most of the time find the code card tucked away in the owners manual pouch.(looks like a bussiness card)If you are unable to find card you would have to pull radio from dash and retrive stereo serial number,which is on bottom side of radio.once you have s/n you can take s/n to any acura dealership(has to be a dealer)and they can get radio code for that stereo through Honda Corp.once you have correct radio code you will need to first unplug radio,or disconnect battery to reset radio memory,then type in radio code.again if entered incorrectly 3x ,radio would need to be reset again too clear error codes.good luck!
Mar 30, 2009 | 1998 Acura CL
Original correct Mercedes verified code fails
Disconnect and reconnect the battery again and try again.
Good Luck
Mar 26, 2009 | 1996 Mercedes-Benz E-Class
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
