Question about Rockford Fosgate Car Audio & Video
How do I add another amp and speakers to my system. I have 3 pre-outs (1 pre-out for subs, and one for four channel amp running front and rear speakers) I'd like to add another 2 channel amp and 2 speakers. Will splitters work off of 4 channel amp?
Yes u can run a splitter with a four channel amp
Posted on Aug 11, 2008
Hook up lanzar 4 channel amp, directions say to use single rca cables with y connectors. my stereo has L/R rca outputs for front, rear & sub total of 3 sets =ing 6. amp has total of 4 one rca...
Well personally i would probably use two channels to run all the highs and bridge the other two channels into one mono to run the sub ..
Jun 02, 2011 | Car Audio & Video
Hi I have just got a JBL SCS200.5 BK, 5.1 loud speaker system. I am having the following problem with connecting the loudspeaker system. 1. I have a satellite TV reciever with a single Left, Right &...
I guess you didn't get the owner's manual, huh?
http://www.jbl.com/HI-IN/Products/Pages/ProductDetails.aspx?PID=SCS200.5BK/230
Where are the amplifiers in this scenario?
Page 8: The sub needs a subwoofer Line Level pre-out from an AV Receiver or multichannel processor. Though not elaborated on in the manual, the L and R Line Level RCA connections are probably for use if you lack a Sub Out feed. Running L and R from your receiver would allow the sub to derive a Sub Channel.
The rest of the speakers would connect to the AVR's speaker outputs.
Pasge 9: Alternate method if your eelctronics lacks a volume-controlled sub pre-out. This method routes only the front speaker level power to the sub so it can extract something resembling an LFE channel, then it routes speaker wire out to the front speakers, not as an audio power source but simply as a pathway.
You still need amplifier channels for all but the sub.
Apr 25, 2011 | Audio Players & Recorders
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
Hello i am rohit i have avh-6850 in my car i want how connect front and rear speaker and subwoofer there only two rc output one is front and other is non-fad & subwoofer tell how to connect front and...
If you only have 2 sets of pre-outs, you will either have to split the fronts into front and rear channels and use the other for a subwoofer signal, or else utilize an equalizer or other preamp that separates out a sub channel. I have an Alpine EQ that I send one stereo pair into, and it sends out front, rear, and sub outs. That allows for front/rear fade, and independent sub level adjustment.
Nov 08, 2010 | Car Audio & Video
Hello. I need help installing an Eclipse sound system in my Dodge Ram 1500 Quad cab. I went from a Kenwood HU with db Drive 6.5's and 5x7's to the Eclipse CD3200 HU and noticed an immediate improvement...
So you wanna run the subs off of the rear pre amp output rather than just the sub out correct? just get a splitter and run both the rear speakers and sub off of rear channel and front off of front channel. or run all four off of front and subs off rear output. this should give you the sound you want
Nov 04, 2010 | Car Audio & Video
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
Hey is ther any why i can run six Speakers off this head unit + an amp and sub system?
The head unit will drive four speakers, 2 front ,2 rear.
Best way to add two more speakers and a sub is to get a 4 channel amp. Hook it up to the RCA jacks from your head unit. Bridge two channels of the amp to drive your sub, and use the other two channels of the amp to drive the extra two speakers. Just make sure whatever amp you get it's bridgeable.
Aug 05, 2009 | Sony CDX-M800 CD Player
I have all the wires running right but for some reason my amp is not picking up or pushing my subs. could the rca jacks be messed up on the stereo?
According to the specs for the xo 1945- the output is; 50W x 4 Max Power Output , and I do not see a pre amp output listed. So I think to connect subs, you will need a separate AMP.
The way this works; the rear speaker wires from the xo 1945 hook into the Add-on amp, for example a 4 channel amp. In a 4 channel amp, the rear speakers come off two of the channels of the add-on, and the subs come off the other two channels. There is also the option of bridging two channels for more output power to ONE sub.
You did not mention what size sub(s) you were thinking of adding, but keep in mind that the ox 1945 puts 50 watts MAX per channel. So, if you add two 12" subs and a 1500 watt amp to drive them, your total sound is going to be very uneven.
If you go on line and look up auto audio or amps, you'll get a good idea of all the Sub and amp options that are available.... Hope this helps.
May 02, 2009 | Car Audio & Video
Adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Apr 08, 2008 | Car Audio & Video
Car audio
Yes you can use the speaker output in conjuction with the rca pre-outs...but depending on the wattage of the amp, there may be a big difference between the loudness of the front speakers over the rear speakers. If you have a 4 channel amp you can put the rear speakers on the amp also and lower the input gain for the rear speaker. Or if you have a 2 channel amp, you could use a passive crossover to filter out some of the bass to the rear speakers since they are smaller, this would help prevent over-driving them...as it is normally too much bass that distorts and blows a speaker. I'm not sure what you are asking about the hi-rear preouts vs the mid front pre-outs. If you decide to use the amp for the fronts you should be able to connect the amp from the front preouts of the deck. Hope this helps.
Mar 30, 2008 | Audio Players & Recorders
Car Audio & Video Logo
47 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
