Question about Rowenta Powerglide DM273 Iron
Rowenta Effective My iron has been leaving rust spots on my clothing. How do I stop that from happening Marilyn B
  • 18 Answers
The rust spot are probably caused by iron in your tap water. I would suggest you put a solution of half vinegar and half water into the water chamber and leave in the iron overnight.
Then switch it on to steam and holding the iron over the sink or over an old towel, the dirt (residue) comes out of the holes on the soleplate. Sometimes if the iron is badly scaled you might need to repeat the descaling.
Once complete, fill again with clean water and steam away, to flush any of the remaining vinegar out of the iron.
Depending on how often you use your iron and how much iron is in your water, you might consider performing this flush process every 2 or 3 months. It will help extend the life of your iron.
Another option is to use distilled water in your iron. Distilled water has all the minerals removed.
Good Luck!
Posted on Aug 11, 2008
Rust coming from iron
you may use any safe rust removing solution, like wd40 and other solutiosn of the same kind. make sure you clean it cold okay
Aug 11, 2008 | Rowenta Powerglide DM273 Iron
Brown dirt coming out of steam iron
You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
Jul 01, 2009 | Sunbeam 4214 Iron
Steam keeps coming out rusty, leaves marks on clothing. model ir5410
The iron needs to be taken apart and cleaned. If it gets rusty again, it's a poorly designed iron and you'd be better off with a replacement. Steam Irons should not rust!!
May 05, 2009 | Rival Irons
Dripping brown-spotted water on clothes while ironing.
Your water could have high iron content, therefore empty out the old water and use Distilled water in the iron.
If you are using Distilled water already then it's a problem with the inside of the iron. Get a new iron.
Apr 22, 2009 | Rowenta Effective DX1900 Iron with Auto...
2 screws on bottom of iron are rusted
they do take a special tool. However I have used an allen wrench and it will remove them. Take them to a local hardware store or sears and get the same screw thread pitch in stainless steel and with a phillips or slotted head
Dec 30, 2008 | Rowenta Powerglide DM273 Iron
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
See if you can get a hold of some CLR (Calcium, Lime, and Rust). It's a cleaner most drug stores and hardware stores carried in the states. Pour that into the system and then flush it out. Make sure the CLR isn't in the iron before you use it again.
Use filter water in your iron in case there is rust or sediment in the tap.
Rust from iron
replace the iron as not worth fixing.
Rowenta Powerglide DM273 Iron Logo
452 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
