Using the Caller ID and Redial Lists Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information. Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
System pool is 300 numbers, personal is 20. There are logging and overwrite options in Maintenance programming 9.3 or system program 737 and 738. Then you program buttons for CID-Select and CID-Indication for either personal, system or both. (2 buttons per feature).
You need to enable caller id in order to see the numbers of the people who are calling you. Caller id costs about $6.50 per month depending on which phone company you use. When you have it activated, and you want to see the number of the last person who called you press the down button on the dial in the center of your phone and it shows the last one. If you continue pressing the down button you can see all callers as long as they have not blocked their numbers.
If your system is a TA-824 or higher and you have Caller ID, you can set a button that will capture the CID of the last calls you have answered on your set. The feature is called Caller-ID Personal and it requires 2 left side buttons on the phone to be preprogrammed for that feature.
Label them CID-S and CID-I. I put them on buttons 11 and 12 (counting from bottom to top) in the S and I order. To do that, press PROGRAM the button and dial 7 STORE for Indicate and 6 STORE for Select. Now, when a call comes in, it will save under the buttons and you can view them with tie I and S buttons and the navigator up and down arrows.
Caller ID on cellular phones works different than on landline phones. Unless the person calling is saved to your phonebook, it will tell you the number of the person calling, but not the name (unless the person calling has caller ID blocking, in which case it will say blocked). There is not way to change this, as it is a limitation of cellular caller ID systems.
Telephone settings Select Menu > Tools > Settings > Phone. Select from the following: • Call — Define general call settings.
Call settings To display your phone number to the person you are calling, select Call > Send my caller ID > Yes. To let the network determine whether your caller ID is sent, select Set by network.
Go to the person's contact you wish to set a picture to. Select that contact and then select edit. Scroll down to where it says picture. Click Set ( left soft key) then it will give you a choice on taking it from your pictures, downloading a pic or some other choices. Choose the one you want and save. Your picture should come up when that person calls you or you call that person. Hope this helps!
I'm also having the same trouble. I bought this new cordless few weeks back but its not showing the caller id of incoming caller. Previously i was having a separate caller id which shows the caller phone no. Pease solve this problem!
Some phones are not equiped to pick up call waiting caller id. check the box or look up your model number on the uniden site. The call waiting caller id only shows up on the phone that is in use at the time of the call.
You cannot unblock your number, from another person's caller ID. That is controlled solely on their end.
There is something called "caller id spoofing", where you pay for a service to forward your calls. One such website ishttp://spooftel.com/
However, it is now against the law for caller id spoofing to be used by anyone other than law enforcement. Here is a link with more information, and information on the laws:
