Question about Sanyo PLV-Z4 Multimedia Projectors
Sanyo Pro XtraX Remote Code
I somehow changed a setting from the projector, so the remote does not function. I did this through onscreen setting while the projector was on, the setting I know changed to 2 by mistake.
The remote does not function with it at all now.
  • 18 Answers
You may have reassigned the projector/remote control codes. If you still have your User's Manual, reference page 38 and there are instructions on how to reset the codes.
If you don't have the User Manual, it can be downloaded at
Please let me know if you have any questions.
Good Luck!
Posted on Aug 11, 2008
  • 2 more comments
  • ben2278 Feb 14, 2011
    I know this is an old post but I just had the same issue and the link above is no longer valid.
    On the remote control, try pressing both the MENU and IMAGE buttons together for at least 10 seconds.
    Taken from the Pro Xtra PLC-XU74 manual, page 47, link here: Database/Instruction Manuals/Projectors/PLC-XU74.pdf
    Worked for me!
  • mark buckley Oct 12, 2011
    i no this is a old post but iv some how done the same on my sanyo plc-xe32 and the links are no longer valid.
  • Mosiesgarcia Oct 28, 2011
    Menu and image works
  • James Hull Nov 23, 2011
    I have the same issue as mark buckley, except i have turned my projector off at the wall. The plc-ex32 doesn't feature an on/off button or any other button for that matter! you need a remote! if the remote gets set to a different remote code and you cannot turn it back on how do you get the remote to work again???
Would not turen back on
It sounds like you changed the remote code, which shuts the remote control off. Can you get into the menu using the controls on the projector itself? If you can, find the remote function and turn it back to the the original code. The factory set code is "code 1", this should get the remote back to normal use.
Good Luck
Jul 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro Xtrax PLC-XU50
Hi there
If you have the know how open up the machine and replace the fuse on the Powersupply board ( where the AC socket sits in )
If this still occurs , I'm afraid you will have to replace the Powersupply board.
Apr 09, 2008 | Sanyo PLC-SU50 Multimedia Projector
Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
Jan 19, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo pro xtrax
I am not understand the exact problem.
Can you pls explain briefly about your problem?
Dec 07, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo pro xtrax projector
listen im a comp wiz on the remote press video 1 egt. if that doesn't work trash it
Sep 20, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLV-Z4 Multimedia Projectors Logo
5,756 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
