Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag wide by side
My refridgerator is not keeping cold. The freezer is working fine. The fan in the bottom back is running continuosly.
  • motorcycle-d Sep 03, 2008
    SAME PROBLEM, I DEFROSTED THE FREEZER AND THE REFRIGERATOR NOW GETS COLD, BUT I CAN'T SEEM TO FIND THE DEFROST TIMER.  HELP?
  • 481 Answers
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Aug 12, 2008
Freezer working, but refridgerator is not cold. The fan works.
You most likely have a failure in the defrost circuit. One or more of thee possibilities: Heating element, defrost timer and/or defrost thermostat.
Check these links:
http://appliancehelponline.com/defrostheatervideo.html
http://appliancehelponline.com/referdefrostheater.html
.g_thread_answer { overflow:visible !important; } X Leave your feedback for the Expert! Write a testimonial (150 Characters max) Submit Testimonial Back
Was this helpful?
Rating helps you get better solutions
Somewhat Helpful
Jun 08, 2010 | Maytag MBB2256G Bottom Freezer...
Maytag Wide by Side Freezer not working
open the freezer panel at the back of the freezer section and check the evaporator fan, it could have been burnt.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refridgerator not cold but freezer working fine
okay this is what you check for, is your freezer back panel covered with ice, if it is then take the panel off and check your heaters for continuity and look at your bimetal thermastat.
another checking point is do you hear the fan running, if not then you need to replace evaporator fan.
Nov 11, 2009 | Amana ABB1927DE Bottom Freezer...
My MayTag refrigerator don't work, but it is on Maximum. The freezer works, and everything works, also the little fan in the freezer,it also works. I need any assitance for problem.
Check all coils for dirt and hair build up.
They can be cleaned with a soft brush and a vacuum.
Some are on the back of the fridge and some are on the bottom. Without proper air flow the heat cannot disapate very well. Check the vent holes inside the refridgerator side to see if something is in the way.
The freezer sends the cold air to the refridgerator through these vent holes.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Maytag refridgerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 06, 2009 | Maytag MSD2651 HE Side by Side...
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Maytag MZD2766GES Side by Side Refrigerator Logo
119 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
