Question about Casablanca Fan 3245T Ceiling
Flickering/buzzing CFLs when turning on W-32 and Casablanca fan. I had compact fluorescent lights in my Casablanca fan with an older W-11/12 swtich and the lights turned on cleanly. Then I upgraded to the modern-looking W-32 and when turning the CFLs on I briefly got a distracting flickering/buzzing. I've replaced them with old incandescents and all is OK again. Any solutions (other than hoarding incandescents or reverting to hte W11/12)?
Is the difference that the new one is dimmable or you have installed a dimmer switch as well? If so thats the problem. CFL can't be dimmed and act weird on a transformer. Only option would be to open it and remove the dimmer pack inside the fan or swap to a normal wall switch.
Posted on May 04, 2011
  • Treefrog15
    Treefrog15 Aug 10, 2011
    The W-32 controller is not designed to work with a CFL that is not dimmable with a normal dimmer. The simplest solution is to install normal incandescent lamps, or find a CFL that is dimmable with a normal incandescent dimmer.
How do you operate a inteli-touch casablanca ceiling fan
i looked everywhere,casablanca doesnt have anything but a picture,but,i eventually found this for you,dont break it,there are no parts being made http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ReplaceElectronicsIT.pdf
May 28, 2015 | Casablanca Fan CAS 66668T Panama II...
I have a Casablanca slumber three delta ii that I want to get a light fixture to fit. Can I use a Hunter, or are there certain ones I need to use?
You have to use the bottom plate to attach the light kit to so whatever you get ,you have to be able to screw the two screws back on the fan. I have some older Casablanca light kits that will work without the bottom cap. fanman9952@aol.com
May 13, 2015 | Casablanca Fan Dryers
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Casablanca fan has totally stopped working
Probably need to reset receiver in fan. call 1-888-227-2178 and somebody should be able to help you with that.
Dec 29, 2012 | Casablanca Fan Dryers
Can i use a Leviton slide dimmer no. 6631 with a holegen fixture
Incandescent and halogen appear the same to these switches. Basically, if the fixtures has a ballast or the lamp uses gas for illumination (as opposed to filament) it will require a special dimmer made expressly for that use or no dimmer is permitted. Such lamps would be fluorescent, compact fluorescent (aka CFL), high pressure sodium, mercury vapor, etc.
There are also some DIMABLE CFLs on the market. These can be used with ordinary dimmers and require no special wiring. Simply remove the old incandescent and replace with a dimaable CFL. Be sure to read the package for any limitations. Keep in mind, the CFL package must state it is dimable, as not all are. Dimable CFLs cost more than the non-dimable types.
Even though it was not asked, never use a dimmer to control the speed of a fan. That applies whether it is a paddle fan or a table fan plugged into an outlet that is controlled by a dimmer switch. There are variable speed motor controls made for this purpose.
I hope this helps & good luck!
Dec 25, 2011 | Leviton Electrical Supplies
I installed a fan and it works good but the light
Is it a standard incandescent bulb or is it a compact fluorescent light? If it has a remote with a dimmer you shouldn't use a compact fluorescent bulb as they are not dimmable. CFLs may be damaged or damage a dimmer if they are used together.
Feb 27, 2010 | Hunter 52" Ceiling Fan With Light And...
Casablanca ceiling fan lights flicker out
here is solution for you.
instead of put all Fluorescent light bulb, put one incandescent bulb.
Dont' ask why but it works. (use 60w or above)
Mar 15, 2009 | Dryers
Ceiling fan light flecker
Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
Sep 02, 2017 | Casablanca Fan Stealth 3211T Ceiling
Hampton Bay 54" Covington Ceiling Fan light problem
Solids state fan controls don't work correctly with fluorescent bulbs. If you check the tail end of you remote's instructions it will say something like "Max light watts: 300 (incandescent only). So replace your energy saver bulbs with 60 watt "regular" bulbs to solve your problem.
Aug 22, 2008 | Heating & Cooling
Fluorescent light that keeps flickering
The ballast is a device that utilises and expanding/contracting electromagnetic field to create the high voltage which is needed to run fluorescent lights.
It is normally found behind the front cover or reflector part of the fitting and looks like a small box.
Replacement should normally be done by a person qualified in this field.
Oct 26, 2007 | Sea Gull Lighting Sea Gull Energy Saving...
Casablanca Fan 3245T Ceiling Logo
477 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
