Question about Gateway Computers & Internet
Unable to get any sound from the speakers. - Gateway Computers & Internet
    Novelist:
  • 202 Answers
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
Posted on Aug 13, 2008
Right speaker has no sound
Check R cable from source to speaker, No power used in L or R cable, they only receive the signal from SOURCE to speaker, You onlly have 2 ends of each cable, 1 to source other end to speaker
Mar 13, 2015 | JBL Pebbles 2.0 Speaker System 2-Piece
Turning off mute
windows? on the task bar look for the little speaker near the time/date. click on it to reveal your sound level adjustment, click to change the volume and the little disabled speaker will change to enabled. if no little speaker there, click on control panel, then sound, then on plaback tab right-click on speakers and then levels tab. adjust volume and this will enable the speakers.
Aug 13, 2014 | Acer Aspire Computers & Internet
Need driver for my harman/kardon HK206. Unable to get sound...
If you are unable to get sound from speakers, chances are it's your computer and not the speakers. Speakers do not require a driver to work, the computer has to have the audio driver to make speakers work. To test this theory, simply turn speakers on and plug them into an mp3 player or cell phone (anything with 3.5 mm jack) and turn volume up - should have sound. What you will need to do is find model computer and look for audio driver for that computer.
Mar 03, 2011 | Harman Kardon HK206 Computer Speakers
I am unable to get the speakers to work at all. They will not play system sounds or anything. Troubleshooter suggested that I uninstall and reinstall the speakers. So I uninstalled and went to reinstall...
I don't know what is the operating system you are using with your computer.Still we can check, first we need to find out if the problem is with the speaker or with the computer.
Try these steps
  • connect those speakers with other computer check the sound, if you are getting sound there it means speakers are ok need to check computer audio setup and hardware.
  • If you are not getting any sound connecting speakers with other computer then it is speakers need to replace.
Incase speakers are ok Disconnect the speakers
  • restart the computer,check if there is windows sound if not
  • right click on the volume control icon on the left hand button corner of the screen,uncheck the mute option.still not getting any sound?
  • try to download the audio driver from the dell support site.still not getting
  • need to check the internal speaker connection,if it is fine
  • go to this website http://www.kellys-korner-xp.com/xp_tweaks.htm and click on Restore sound -windows Audio service and run the tweak,YOU NEED TO USE INTERNET EXPLORER
  • still you cannot hear the sound change the internal speaker.
Sep 26, 2010 | Dell A215 Computer Speakers
Need drivers for the sound system for my pc w/XP Pro
Just install a sound card .. i prefer Sony sound card...
That will allow to work the speaker..
May 30, 2010 | Cyber Acoustics A-3780 Computer Speakers
I recently purchased a Dell Inspiron. I am unable
download the sound drivers from the dell web site
Feb 18, 2010 | Audio Players & Recorders
Sound to compputer headphones stopped working
go to main screen panel, then go to speaker icon, right click, go to properties, make sure headphones are enabled, volume is turned up, and see if the headphones are set as default. Update drivers if necessary
Aug 27, 2009 | Audio Players & Recorders
No sound when playing dvd from speaker system
I recommend going to the sound icon on bottom of main screen, right click, go to the properties and settings. Make sure the system is set for the same amount of speakers as you have. You can also use the test button and see if the settings are correct.
Make sure you are using the correct audio decoder or ac3 filter
Aug 17, 2009 | Audio Players & Recorders
I can hear sound in head phone where as i am unable to hear sound from speakers
You must set the sound output on your computer either through the motherboard sound controller or through the windows control panel.In each of these sections will be a speaker set-up control allowing you set up the type of sound you want to come out of your computer. Headphones only, speakers only, Headphones and speakers. Hope this helps you with your problem.
May 10, 2009 | Compaq Computers & Internet
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
