Question about Frigidaire GLEQ2152ES Electric Dryer
Frigidaire gleq2152es dryer
Dryer turns on for 30 sec then shuts off has error code takes longer to dry cloths
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Check lint filter is cleaned every load.
And that the outside animal guard where the vent opens outside is clear. If it's even half way clogged it will not dry or get hot!
Otherwise
for this is a situation that you will need service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Displays code E4A , clothes will not dry
Hi Alicia Rosa - Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Nov 25, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer shows error AD
AD = Auto Dry
If the air flow is not good, the unit will retain moist air causing the clothes not to dry and the AD error. Try running the unit with the vent unhooked from the back of the dryer and see if the dryer works properly.
Nov 07, 2012 | Dryers
Why does my frigidaire dryer beep while drying?
How often does it beep and does it flash any error codes at all?
Aug 14, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Error code AD error code DN
it means auto dry it will check the temp of the clothes so if they dryer quicker then 40-45 minutes it will shut off earlier instead of running the full 40-45 minutes. In the manual it says AD is the adjusting time according to moisture level for those who keep drying but display this it is normal for those who display and size to dry is not normal if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 14, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Will no longer spin clothes dry
If it not spinning check the belt and tensioner. If it does sdpin and produces no heat replace the spark ignitor
Apr 06, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer wont dry, clothes are just as damp as they were at the beginning
Is the dryer heating? If not check heat system for part failure. If it is heating but taking too long to dry check for plugged exhaust. Best way to check exhaust is to disconnect exhaust from back of dryer and dry a load.
Mar 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Front load frigidaire will run for 10 sec and shut off. Help.
Reach inside the dryer and turn the drum. Is it difficult to turn? If so you may have bad glides causing the motor to shut down. Or maybe you just have a bad motor my friend.
Feb 04, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Error Code
E68 error code, according the manufacturers operations manual found at this link: ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134431300esa.pdf
Says the the button used to start the machine has either malfunctioned or is "STUCK" in the start postion. Read this link I found and see if it helps. Best of luck to you.
Mar 18, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
124 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
