Question about Mitsubishi Audio Players & Recorders
I have a mga mu-2200 reciever and it shows that it has power but will not recognize tuner, cd, tape, or any volume. i removed the cover and found that 3 of the bus connectors were not connected. still no recognition. please help!!!
Check the fuse thats exactly what happened to mine
Posted on Apr 14, 2010
How do I improve the volume on recorded TV shows?
  • If you record from an outside source, turn up the source (e.g.digital receiver) volume. If recording sound from a VCR's own tuner, tape path, especially the drum(once you open the cover)and linear voice recorder post (to the right after the drum)must be cleaned. Get instructions from the web how to do the cleaning, otherwise you may damage the machine. Switch to hi-fi track if you have one and adjust the tracking.
Mar 04, 2015 | Televison & Video
2006 Prius - battery died, and after jump start, radio is acting strange.
The radio is likely in theft lookout due to loss of battery power. theft lockout.
Feb 01, 2018 | 2006 Toyota Prius
Ang refigerator nmin ay mahina lumamig
kung estimate mu na medyo matagal na refrigerator mu mga 7 years pataas maaaring halos ubos na FREON ng ref mu, make sure na sa 220volts din nakasaksak yung cord. TIPS masdan mu rin ung motor nya sa likod kung subrang init at madalas mag ON and OFF hindi normal yan.
Aug 15, 2011 | Samsung RB215LASH
Hello, I have found a Sansui DA-T550 music-system with AM/FM stereo tuner, integrated amplifier, cassette deck and turnable/gramophone (placed separated). It seems like the system is working OK. My...
Hi!
I have the same deck. Did it come with rammophone or are you using your own grammophone?
I have it with original grammophone and I don't need a remote control, I don't even have it. You just turn on your grammophone and it is automatic, just place the needle on record and it should switch and play automatically. That is if you have connected the wires right (two wires for sound, one for automation, all in the same area).
If you have separate grammophone, I am assuming you just need to place two wires into the separate phono channels and it should work. There is just no automatic detection, so you have to swithc to mono manually: There is a button on the right, beside Volume control "tape to CD" or something.
To play the tape, just simply push the play button on the bottom, should work, or you could try tape to cd button off and see if it detects automatically when tape is inserted.
Currently I have it taken apart and there is tape detection system apparent. Its quite automated reciever, which sucks, because all kinds of problems appear and it is difficult to fix.
On my Sansui, the tape player starts winding slowly when pressed play button. And the tape motor seems to be on always, even when the tape is not used, and the motor is really loud. --Need to find a solution to this problem. And I hate it switch to radio/FM every time the record stops. Plus the original grammophone doesn't work correctly, it is supposed to take off the needle when record reaches an end, but it just pushes the neelde to the holder... over the record..... "screeeeech".
Nov 15, 2010 | Audio Players & Recorders
Connection compatibility
Connect the supplied short RCA "Y" adapter cable to the mini jack of the transmitter base unit. Connect the "Y" adapter plugs to the TAPE 2 "REC" L and R jacks. These jacks will supply "line out" levels of any source selected at the Kenwood to the EWOS1 internal amplifier. The line out levels are "fixed" so changing the volume levels of the Kenwood will NOT change the volume out of the EWOS1 speakers. The EWOS1 volume will be controlled by the volume up / down buttons on the front of each speaker, or by the incuded remote when directed at the speaker(s).
The signals from the TAPE 2 jacks are ALWAYS on regardless of the source selected, so the Kenwood volume can be turned to minium and still provide an unchanged sound level from the EWOS1 speakers. Likewise, if listening to FM, Phono, CD, etc. in the room that the Kenwood's speakers are located, the OWS1 speakers will by playing the same FM, Phono, CD, etc program - unless they have been powered off. The point is, that unlike having to choose FM, CD, etc to listen to those soreces, you should never select TAPE 2 as a source. If TAPE 2 is selected, the KENWOOD would attempt to amplify TAPE 2's "PLAY" jacks, which I assume are not being used.
Mar 20, 2009 | Audio Players & Recorders
Dell CD/DVD shows up in 'My Computer' but doesn't recognize CD's
the cd player could be bad it doesn't seem to be reading anything. or your windows needs reloading because you have other programs overwriting each other and windows.too much on the drive defrag it
Dec 27, 2008 | Dell Inspiron 2200 Notebook
Technics SH -8058
the Technics SH-8058 is a beautiful unit, I got one myself for the past 20 years and never failed y EQuing the sound I want.
I am asuming, you got on your reciever TAPE MONITOR... well, the it is simple,
First, just forget about the TAPE on your Techincs SH 5058
Second, on your Technics LINE OUT, goes on your tape monitor LINE IN
and last; on your LINE IN, goes on your tape monitor REC OUT.
Now, choose you desire componet, and turn on your TAPE MONITOR on your reciever...
enjoy and have fun.
Sep 11, 2008 | Technics SH-GE70 Home Equalizer
Shuts down at high volume
If you have your reciever in an entertainment center that is enclosed or a tight fit for the reciever you need to remove it and put it on top of the center. I have a VR407 and it was doing the same thing. This keeps your unit much cooler and the overheat relay will not turn it off. also I found it much easier to add or wire components much easier.
Steve T. PA
Nov 25, 2007 | Kenwood VR-407 Receiver
229 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
