Error massage on display screen saying belt jam is as a result that the oven conveyor motor failure. If it does not move or function. The fault could be inside the motor circuit that contains hall effect sensor, the motor could be stack, or the controll boar may require cleaning wit dryclener liquids.
Sibuor, I am having this same issue with my Lincoln Conveyor Oven. Does this mean I need to replace the conveyor motor? Is there a fix I can do on the fly since I am at an event and need the oven now?
Before you replace the motor please first check the motor brushes, then check the hall effect sensor which is mounted on the conveyor motor, also check that the fuses on the control board are not blown.
