hi Zoooya.
try this.
1]Go to control pannel
2]Go to System and Security
3]Go to Device Manager
4]Click Universal Serial Bus Controllers
5]Right click the USB
6]Click Uninstall
then Reboot computer while pendrive is inserted in USB
Then connect to the internet.
When you connect to the internet if the said USB is empty
(i.e. no device is inserted in it) they install the device
even though the device is not present, causing the said error.
or this.
Try the steps below:
1. Make sure you update to latest BIOS.
2. Reinstall USB controllersFirst, please disconnect all USB devices and then perform the following steps:
a) Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
b) In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
c) Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
3. If the above steps cannot resolve the problem, try the steps below:a) Turned the laptop off, unplugged it.
b) Pulled out the battery for a few minutes.
c) Then power on the laptop.
Make sure the USB device is working, try changing to another USB port.
5. Also, you can try in-place upgrade your system or system restore from the Windows Recovery Environment (WinRE)
At boot-up, Hit F8 --> Repair --> System Recovery Options Window --> System Restore.
or this link if you need more info on this matter.
pc one of the USB device attached to this computer is malfunctioned and...
