Question about Sharp 21" Multi System Stereo TV
Connect dvd player to tv
I have a Toshiba dvd player & have connected to a sharp flat screen tv, I have sound but the image is black & white. How can I make it color? Please help.
  • Anonymous Jan 06, 2009
    I have the same problem
    Problem Solver:
  • 17 Answers
Look in the tv if input if only for HD or have other imput,may be you have put in the input wrong
Posted on Aug 11, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Flat screen to dvd connection help!
It depends on the TV.
On my Phillips TV this is switchable via the TV setup menu, and you get no sound with HDMI unless you change that setting.
The reason it's switchable is that the HDMI input is usually common with one of the component-video inputs (AV3 on mine). (cost saving move)
Thus if the menu is set to hdmi, then the audio goes thru hdmi. If it's set to 'component' then it goes thru the RCA patch cable.
Oct 07, 2009 | Televison & Video
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remove Base from Toshiba Regz 42RV530U
I bought this LG flat TV at Circuit City last week. TV is okay, but I was trying to hook up my portable DVD player and I can not make it work. I can hear the sound that coming out from the DVD but theres no picture from the screen. I believe my connection is correct, because there is the color coding which is red, yellow and white which you just connect at the back of the TV and at the DVD player.
Can anyone help me to figure out the problem. thanks a lot
Jan 31, 2009 | Toshiba REGZA 47HL167 TV
DVD picture is in Black & White only.
Are you trying to play an NTSC disc in a PAL player, If so,your player has a switch or
on-screen setting to select the output format for NTSC discs,
Or maybe you have connected one of the component outputs (Y, R-Y, or B-Y) of
your DVD player to the composite input of your TV.
Please rate this solution
Jan 20, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Dvd player connection to tv
possible reason could be:the cables are corrected wrongly,if you use RCA type please ensure the color coding is correct and are firmly in place..
Nov 06, 2008 | Sharp 21" Multi System Stereo TV
No colour when dvd player connected to tv
I would try a different set of cables to hook up the dvd player, sounds like you either have bad wires or bad ports on either the tv or dvd player. Test each and see which one it is, hopefully it's only a set of cables.
May 05, 2008 | Samsung TX-R2735 27" TV
'SHARP LC 26SH12U' & Philps DVP 5160
sounds like you are using standard audio/video cables (yellow, blk., wht) in the component conections on either the tv, vcr or dvd player. If you intend on using component connection you will need to use different cables.
May 04, 2008 | Televison & Video
Televison & Video Logo
123 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
