Computers & Internet Logo
Anonymous Posted on May 04, 2011
I can't change my letters back to normal size. They are teeny tiny.
  • 1 more comment
  • Anonymous May 04, 2011
    I'm using Mozilla Firefox not Internet Explorer and everything else on my computer is correct. Only the letter size when I'm on facebook.
    That's it!! You're awesome. I have been trying to figure this out for 2 days!! Thank You very much!!
    That's the ticket! Thank you very very much. I have been going nuts trying to figure this out!!
Anonymous
Level 3:
Genius:
  • Master 1,570 Answers
  • Posted on May 04, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1570
Questions
0
Helped
385547
Points
4486
Hi
Which one is tiny text? From the desktop setting screen?
If yes, right click on the desktop and choose display setting and choose the desired resolution.
If not, check if you are using internet explorer 8 or 9 and in the lower extreme right side of the internet explorer, there is a +100% (Zoom Level) ICON ON THE EXTREME BUTTOM RIGHT SIDE. Adjust the desired zoom level setting you preferred.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
    Ah on Facebook only. Try this solution
    You need to press ctrl and + key together to make them bigger. Ctrl and - key to make them smaller again.
    Hi
    Welcome and Thank you for using Fixya. Have a nice day !
1helpful
My t.v. won't work correcrly. All it shows is a teeny tiny television picture in the upper right hand corner. I can't get the guide or change channels or anything!!! HELP
Unplug the cable box or turn off the power strip to everything. Wait five minutes. Plug everything back in. Let the cable box complete its reboot. Sometimes thse cable boxes get confused and have to be reset. The box will take its own good time to finish booting and your tv will likely appear as per normal. (Otherwise, you may have hit a PIP button on your remote.)
How do I cancel the child lock on my microwave
Look for some button that has some teeny-tiny print beneath it that says something like "Lock - hold for 3 sec". Press and hold that button for 3 or more seconds, and your microwave should function normally.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1helpful
The screen on Firefox is huge and I can't find a way to reduce it back to normal size.
If you click on view- you will able to set your zoom back to normal size.
When printing incoming hotmail message, the subject line is printed in very large & bold letters
Click on the 'print' icon to display a print compatible version, then print. If the problem still exists, use google chrome to change the html code of the text to manually change text size
I changed my local disk c name and now it cant open unless i run safe mode how can i fix this?
C is the root drive for your operating system so it is not advisable to change the drive letter of C drive. If you are still able to open your computer in Safe mood then I'll suggest you to change the Drive letter of C back to C in safe mood.
I hope you know how to change it back to normal position. If not then here the steps.
Open in safe mood
Right Click My computer-------Manage-------Disk Management------Right hand side at Bottom you'll see the Bar showing Size of the Partition in blue color ------Right Click the Drive C(which was C earlier)-------Change Drive Letter--------Change ------Here select C as your drive( remeber if you have Given C as a name to other drive then remove it before doing the above steps).
Hope this will work for you. If still you are facing problem then here is noe more way to restore drive back to normal position.
Start-----All Program----- Accessories------System tools-----System Restore----NEXT-----Check Show more restore Point(In Win 7)---now select the earlier date when your computer was fine and click next.
it'll restart your computer after restore is done.
Hope this will work for you. Good Luck
I am using Omnipage 17 through Microsoft Word 2003 wth an HP scanner. I am scanning text. The default page setting is for legal size paper, and there is a long list of paper sizes one has to scroll through...
Linda I suspect you can open a template called normal.dot and change the paper size then save the template.
see
http://www.geekstogo.com/forum/topic/131676-change-office-word-default-paper-size/ - the second answer given ..
I can't change the letter size of my words on facebook. They are super small and I want them back to normal.
It all depends on your internet browser, I couldn't find anything to change text on facebook itself.
For firefox at the top of the screen go to view>zoom then click zoom text only, then go view>zoom>zoom in.
There will be a tick beside the zoom text only to let you know this function is on.
For internet explorer, go to view>text size and then decide which size you would like.
For google chrome the only thing I can see is just to zoom the page in, can't immediately see a text specific option.
2answers
Font size automatically switched to tiny and I can't change.
If you erase the December 7th and it reverts to the larger font,probably have a setting of "FIT TO SIZE and the machine is reducing the size to fit.
I want l LARGE but all I gei is teeny tiny
You can't transfer thumbnails and enlarge them. That's why they are called thumbnails. You have to download the full size pictures from the camera to the pc
Grand Canyon Tech
Grand Canyon Tech
