Question about Brother HL 2140 Laser Printer
Can i set the Brother HL-2140 to print double sided. I cannot find it ?
  • 4 Answers
The Brother HL-2140 does not include duplex printing. The only option for double sided printing with this model is to print odd numbered pages, then manually replace the paper into the tray and print the even numbered pages in a second set.
Regards,
Dan
IT Professional
Posted on May 04, 2011
SOURCE:
How can I print on both sides of my page?
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
For details, please click on this link and follow my instructions :- http://www.fixya.com/support/r7325259-double_sided_printing_using_single_sided
Mar 10, 2011 | Brother HL 2140 Laser Printer
If im going to print my document the selection for printer HL - 2140 series 2 was lost and replace by the printer generic how can I reset the printer bask to HL - 2140 inorder to activate?
Brother HL - 2140 Drivers
Visit the above link from Brother Official Support. Select the Operating System and download the drivers. After in stalling the drivers, go to the Control Pannel - Printers, and set HL-2140 as default printer.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 24, 2011 | Office Equipment & Supplies
I recently installed the Brother HL-2140 to my computer, everything came through, but I am not able to print. Rose
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
Oct 05, 2010 | Brother HL 2140 Laser Printer
How can I check the count of pages printed in my brother hl-2140 printer ?
Turn the printer off then on, wait a few secondes then press the GO button 3 times quickly.
The printer settings will print. It will show you how many pages have been printed as well as number of paper jams and errors etc.
Jun 11, 2010 | Brother HL 2140 Laser Printer
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Sep 30, 2009 | Brother HL 2140 Laser Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Brother HL-2140 won't print from Firefox (or IE)
am not very sure but i think u should try go to printers and faxes through control panel open it and right click on your printer and select print on line
Jul 17, 2009 | Brother HL 2140 Laser Printer
Can i print envelopes addresses on brother HL 2140 laser printers
The manual by-pass slot just below the brother name on the front allows a user to load envelopes just put the envelope in the slot and adjust the size.by closing the two grey tabs
Nov 25, 2008 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
614 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
