Question about EliteGroup K7S5A Pro Motherboard
USB Port won't recognize plug n Play devices
This mother board is connected to a box that has front panel usb 1.1 usb hubs. They are enabled and connected to the motherboard. However, the four 2.0 usb hubs continue to return error messages that the usb device has malfunctioned or is not recognized. Thoughts on what Bios settings might be fouling this up? Can I just add a 2.0 USB card to the system and override the problem?
  • rherberger2 Aug 11, 2008
    Not sure. I have not tried to upgrade. I am running XP Pro.
  • rherberger2 Aug 12, 2008
    Thanks, I will try that.
  • 781 Answers
Do you have the upgrade for your O/S to recognize usb 2 as sometimes when first plugged in a usb device my computer has come up with your usb is 1.1 you need to upgrade to sp2 or whatever to have usb2
Posted on Aug 11, 2008
My acer aspire 5733Z-4851 donot read usb
That could be a problem with the USB connection on your motherboard. This is not a big issue, if you can you just open up your CPU and locate the USB connection on the motherboard. It is not clear to me whether it is the USB ports from the front panel or it is the USB ports that are on-board (usually found at the back). If it is the USB ports from the back, the one built - in on the board, then the BIOS has to be configured again to enable Plug and Play attributes. If the ports are from front then you need to follow the cable that connects the usb port to the mother board. Disconnect and reconnect. Or check whether it is actually connected to the right port on the motherboard. Usually it is written on the motherboard.
Jun 11, 2012 | Acer Aspire 5733z-4851
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
Hi , I Am using Mercury P1845Z mother board. How can i connect/enable the front panel USB. I tried fixing the pins i the F_USB , but there is no effect. Please help me to resolve this issue
Hi, you maybe need the usb driver from here:
http://www.mercury-pc.com/downloads_list.php?productid=857
Try also to look in the bios in the settings for the usb
it could be set off
The connector look like this you can`t plug it in wrong.
Sep 04, 2011 | Mercury P4VM800M7 Motherboard
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
I want to get a usb 3.0 hub and plug it to the asus p8p67 pro on the middle of the mother board. What kind of connection is it?
The header bus above is for the USB Front Panel interface:
This is included in many of the various flavors of the MoBo. If you're looking to use the MoBo connector to supply something other than this Front Panel interface, you're going to need to obtain the pinout of the jack on the motherboard and compare it to the signals required by your USB 3.0 device. The one from Asus is simply gathers the wires and forms them in a single shell - then keys the shell to prevent reverse insertion.
Think of what you have to do as the way USB 2.0 headers are provided on MoBo and the way PC cases have USB jacks built in. The USB header isn't standard; some have 9 pins - some even have 10! They can't seem to get on the same page as to how many pins are needed. The location of the signals on the header are probably different from brand to brand, too. So, the case manufacturers break up all the individual wires and label the signal so that YOU can check the MoBo manual and plug each one in to the correct pin.
May 06, 2011 | ASUS P8P67 PRO - ATX - INTEL P67 - SOCKET...
Dear i have problem in my frent panel cuble... can you tell me where i put these cuble
On the mother board 3 plug in connecters are there
USB 1
USB 2
Front Audio
You can connect the front pannel cable accordingly.
Apr 28, 2011 | Intel Motherboard
The power cable from the front panel to the pins on the mother board is off
if it is connected with board properly go to bios option select all usb port enable
Dec 15, 2009 | Intel Computers & Internet
VIA Technologies, Inc. PC Model KM400-8235
Probably the cables your are referring to are the front bezel USB and Audio Panel connector .If you do not use front USB port on your cab leave it NC .
Apr 28, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mercury MOTHERBOARD KOB P4M266 NDFSMX
I AM NOT HAVING MOTHER BOARD CD TO INSTALL HIS DREVERS AND HOW TO DOWNLOAD HIS DRVIERS BY INTERNET
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
EliteGroup K7S5A Pro Motherboard Logo
211 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
