Question about Garmin nuvi 200W GPS Receiver
Locked downloaded 2009 to novi200W from disc i purchased, and now it tells me my maps are locked and wonr read them
    Scholar:
  • 162 Answers
There are a few things you can do. Right now it sounds like you over wrote your original maps that came with the unit. Connect it via USB, it should come up with a drive letter or the name GARMIN. Open that drive, double click on the GARMIN folder, and in the folder, there should be a file called gmapprom.img. Change the name to gmapsupp.img and try that.
Posted on Aug 22, 2008
2009 Jeep Wrangler 3.8 PO113 code
will cause limphome ,low power, and mpg bad, and CEL glow.
IAT is major sensor on MAP EFI.
the IAT reads too high, id bet it's unplugged.
or was removed and dropped to the pavement and broken inside.
the eCU reports this when the input hits near 5vdc.
this is and open circuit stated.
fell off, wires bad. connector bad. dead open sensor bad.
my fsm has no IAT resistance table. (sad)
my garage is 60f and my sensor reads 16k ohms (16,000)
with hot water (tap at sink) running over it , it might read
3000 ohms, or 3k. it is a NTC sensor, more heat , lower ohms.
the sensor is double locked, so never fall off.
slide red lock up, and mush lever down and pull conn. off sensor.
3 steps.
THE fsm STATES
K21) IAT SIGNAL CIRCUIT SHORTED TO VOLTAGE (12V?)
(K21) IAT SIGNAL CIRCUIT OPEN (FELL OFF?)
(K900) SENSOR GROUND CIRCUIT OPEN (FELL OFF)
IAT SENSOR (BAD)
POWERTRAIN CONTROL MODULE (PCM) nah.
Mar 09, 2014 | 2009 Jeep Wrangler 3.8
I purchased Garmin1490t and it says "Cannot unlock maps" / 'No maps Found" Please help
If your Nüvi keep displaying the maps are locked, you will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then 'My Computer', and double click on your device file (mass storage system), there you will see a folder named 'Garmin'.
In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
Other choice, could be one read at No Detailed Maps Found That Support Routing
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Garmin nuvi 255W GPS Receiver
I tried to update my new Garmin Nuvi 255w. It now reads as follows, No detail maps found that support routing. The nuvi cannot be used without them. I have a ABI and to help me even to get home is hard....
There are 2 possible reasons for this. The most likely is that the map is not selected. Go to Tools, Settings, Map and press Map Info. Is the map ticked. If not press it and it will tick. The map should then work.
The other reason is that the map may be locked. The instructions for unlocking the map are at http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=nuvi%20770
Jul 27, 2010 | GPS
Is there any updated map for streetpilot 2620 since 2008?
Yes. There is one more mapset and then there will be no more for us using the StreetPilot 2620. You are looking for the disc set North American Navigator 2009. Make sure you do not purchase the NT version. I found the item on EBAY for $81and purchased it and it worked just fine. The 2009 is the last compatible map set that Garmin released for the 2620. Be certain that what you purchase includes that unlock key otherwise you will spend another $75 on that at the Garmin Unlock Site.
Here is the link that is good for a few more days, however, may relist it. The seller is yumelectronics and the search term is 2009 City Navigator.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390193775928
Here is the search for EBAY:
http://shop.ebay.com/i.html?_nkw=city+navigator+2009
Here is the item on Garmin's site:
https://buy.garmin.com/shop/shop.do?pID=8465
Listed as:
City Navigator® North America This product has been discontinued but is still available for purchase.
It is $99.99.
Good luck, and let me know if you have any other questions.
May 11, 2010 | Garmin StreetPilot 2620 GPS Receiver
Garmin Nuvi 205 can't unlock maps
First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
Please email me at sharcnet-usa AT sharc DOT NET
- Jim
Mar 25, 2010 | Garmin nuvi 205W GPS Receiver
My sgh-i617 gps is locked, to force you into downloading maps
Remove the battery for sometime and then reinsert it and power on the device. I do not know what maps you are using. I would recommend google maps v 3.2. Download it from maps.google.com or from m.google.com/maps.
Oct 30, 2009 | Samsung BlackJack II Smartphone
Suddenly all detailed maps are locked, I can't unlock them
I had the same problem so I went to garmin.com/kenwood and downloaded the latest update to my pc unzipped the file and burned it to a cd put the cd in my dnx5120 and updated my system and my maps came back ... read the install instruction on their web site and this should solve the problem at least it did for me ....good luck hope this was helpful to all ...
Jan 02, 2009 | Kenwood DNX5120 DVD Navigation System GPS...
Garmin 600/650
Most likely you had the 2007 or 2008 maps. Click on the wrench icon, then the maps symbol and then the word "info" or "about" and you should see the current map revision. If you updated it recently, it should now show 2009.
- Jim
Sep 29, 2008 | Garmin Nuvi 660 GPS Receiver
Cannot upload update
Problem resolved. It seems to have taken several hours for gps to update.
Thanks anyway.
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
56 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
