Question about GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
Compressor not starting
Compressor drawing 150 ampers and tripping out .but coil not contenuity to ground. suspect bad compressor but cannot rule it out.
  • 182 Answers
You have locked rotors more than likely.there's a very slight chance you could have a bad capacitor.
Posted on Aug 11, 2008
Taking high ampere and tripping
Remove the belt and test motor for amp draw. If motor runs normal, most likely problem with compressor or check valve. If still high amp could be short in windings or motor start switch stuck on. If motor does not turn (loud hum) try spinning by hand to see if it starts. If motors runs after spin by hand, bad capacitor. Good luck
Oct 29, 2015 | Ingersoll Rand Air Tools & Compressors
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
Aircon tripps circuit breaker
Usually a short in the system or its drawing to much power for the breaker to handle. most common cause is a bad capacitor, Locked up compressor or compressor has gone to ground.
Aug 30, 2014 | Dometic Rooftop RV Air Conditioner
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
Breaker keeps tripping on outside air conditioner unit
The compressor is probably drawing to many amps. Breaker could be weak also.. Need to check the amp draw on the compressor.
If the breaker is hot when it blows, the compressor is probably going bad.
Jul 27, 2010 | Ruud Central System Air Conditioner
Air Conditioner trips the 110v breaker, only when the outside temp is above 90 degrees. Unit has been checked several time and the circuit board has been replaced, but has fixed the problem of tripping the...
'Breakers' - are tripped because they are exceeding their amp limits.
The 'hotter' it gets outside - the 'harder' your AC has to work - and under normal circumstances this is not a problem - but when you have a fan motor or a compressor that is starting to 'break-down' (electrically) - often the AC's amp draw will exceed the limits of the breaker - thus 'tripping' the breaker.
I would suspect either the fan motor or the compressor is causing your breaker problem.
Eventually - the component (either the fan mtr or compressor) that is 'going bad' will go out completely and your breaker will 'trip' and not stay on when you try to reset it.
At this point you will need a Service Tech to determine which one is bad.
There is a possibility that your condenser coil (the one that blows hot air) is 'dirty' which will also cause a problem similar to the one you have - but it is less likely.
Also - if you've had the AC 're-charged' lately - it's possible you are in a 'over-charged' condition - but again, this is not very likely.
hope this helps.
Jun 06, 2010 | Dometic Rooftop RV Air Conditioner
MY 2005 DODGE DURANGO WILL NOT START UNLESS IT IS JUMPED. THE BATTERY POWER WAS TESTED AT ADVANCED AUTO. ACCORDING TO THE SALES REP, THE POWER WAS GOOD (450 OUT OF 600). WHAT COULD BE THE PROBLEM?
450 out of 600 what? sounds like you have somthing drawing power need an amp meter. remove key and leave window down. disconnect negitive battery cable and connect meter between the negitive cable and negitive termainal on the battery should see around 2.5 milliamp draw or less may take 1/2 hour to get to this point. also if this vechile is not driven often this could be the problem
Aug 23, 2009 | 2005 Dodge Durango
U-line 29RBK Repair
First, reset the breaker. If the unit restarts, you're okay. If possible, change to another good circuit of comparable rating...generally at least 15-20 amperes...sometimes the breakers go bad. You may have a bad compressor or compressor start relay. We can only know about that after the breaker is ruled out as a cause. Oh, and be sure the plug contacts are not corroded. If they are: use a little steel wool to clean them and remove all strands when you're done.
Dec 22, 2007 | U-Line 75R Refrigerator
GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0 Logo
89 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
