Home | Sharp | -COPIERS - AR-5316 Advanced Digital Ima... | A new sharp ar 5316e pho...
Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
Problem for Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier
A new sharp ar 5316e photocopy machine photocopy blank
By cibcomputing on Aug 11, 2008
i bought a sharp ar 5316e photocopier and after inserting the toner and tried to photocopy a document and my result was blank
Sponsored Links
Same Problem
May 10, 2009
-   how do i add developer to my sharp copier? -   aloma741
Sep 15, 2008
-   I just purchased a Sharp AR-5316E, after inserting the toner and powering it on it prints black copies. The documents are placed face down in the scanning bed, so I know that's not the problem. Could it be a developer issue?-   bethroe
Best Solution
posted on Aug 11, 2008
Helpful)
scrodamoon
Rank: Guru
Rating: 85%, 331 votes
the origional is not placed face up in the spf or face down on the scanner bed.
Comments:
Aug 11, 2008
- here is the manual if you need it for your unit
http://www.sharpusa.com/files/cop_man_AR5316.pdf
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 04, 2009
Somewhat Helpful)
ashwaj
Rank: Guide
Rating: 92%, 3 votes
My name is Asiwaju Abdullahi and I happen to be one of the engineers working with CFAO TECHNOLOGIES, Ibadan branch Nigeria. With this kind of problem mentioning two things can happened: (1) At times due to stiffness of the rail which hinder the movement of the scanning unit from the initialisation stage to the copying stage at times when duly checked after pressing print button you will noticed that the scanner unit does't move thereby there will be only picking of the paper either from the cassette or bye-pass unit sure the signals which are supposed to be transferred from the LSU to OPC unit will not be occur. so, in this sense you should be expectin total blank copy frtom the so-called copier. Hold on to this or if there's any info you can reach me on 08024797289, 08138000222. Thanks
Was this helpful?
Yes
No
Solution #3
posted on May 23, 2009
Not Rated)
alpe2gade
Rank: Apprentice
Rating: 0%, 0 votes
change the main charger because based on my experienced it has an arching problem
Was this helpful?
Yes
No
Popular Solutions for Sharp -COPIERS - AR-5316
Questions and Unsolved Problems for Sharp -COPIERS - AR-5316
Do you recommend Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier?
Answer
Answer
im facing one problem if e 004 service code for canon 7161 what is the solution?
Answer
5/19-20 T trmai E trmakr J krijaniburrie 71120
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp -COPIERS - AR-5316...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1467
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
